Well I tracked down the source of an odd noise my Insight Engine started making a little while ago. The AC compressor and AC clutch are both bad.
In my service manual page 10-8 and 10-9 it shows two different belt arrangements one with AC and one without AC. The AC compressor and clutch just look like an add on to the basic non-AC system.
I asked local Honda dealer about what they would charge to repair or remove it... $1,600 to repair ... and they claim it is impossible to remove as the AC is an integral part of the engine... Well their price was too high and I didn't like their bit about it being impossible either.
Now eventually I had planned to change my AC system anyway to a different setup... so the removal of the OEM AC was kind of already on my to do list... timing is not the best with plenty of other projects already going on... but oh well.
I haven't removed it yet... the car still runs ... and I feel as though I still have some time to iron out my options ... The compressor is still spinning freely ... if someday it were to seize up , sense the AC clutch is bad as well ... that would mean in a short period of time that belt would be toast... and the major issue with that is the water pump is driven from that belt... but I suspect I would notice if either of those happen ... and although not ideal , as long as I don't over heat the engine I should still be able to limp around like that even with no belt for very short trips if needed.
As I see it I don't want to leave it the way it is long term... the compressor seizing up is a potential issue ... right now it's just dead weight.
I am currently weighing the pros and cons of two different options ...
#1> Just remove the OEM AC compressor and clutch short term ... and eventually remove all the OEM AC system replacing the belt with the non-AC configuration shown in the service manual.
#2> Remove the OEM AC system and install a small electric motor to drive the water pump.
#1 is the more straight forward option ... but it occurs to me that #2 offers a few additional things ... it would give the ability to turn it off in cold weather, effectively a radiator block ... but better sense it can be turned back on any time .... and by moving the load off the engine to a electrical source it would make it a tiny bit easier to stay in lean burn , at least as long as you were not doing any regen , either from high SoC , or from MIMA control.
but there you go... so now you know... feedback / thoughts are welcome.
Thankfully it is coming into nicer weather ... I am not a fan of doing outside work in the winter.
