Regarding the "*uhtrinity" positive recal, I just found out some more information using the following scenario:
1) After topping off battery, it is purposely drained it to/from work to exercise it
2) After getting the battery down to about 145 volts after getting home it is again trickle charged using the Dabrowski grid charger
3) Without pulling fuse #4, if the voltage is within 165 volts from being topped off, turning on the ignition key and waiting 2 minutes will automatically cause a positive recal
If on the other hand the #4 fuse is pulled to reset the BCM, the voltage needed for a positive recal is about 169 or so. Don't know why the difference, but that is what I measured thus far.
* A uhtrinity recal is one where starting the gas engine to cause the positive recal is NOT needed. Simply get the battery voltage high enough from trickle charging, turn on the ignition key to display the dash, and simply wait two minutes for the recal. If it does not occur then the battery voltage is still too low.
Jim.
