Originally Posted by Artric
60 watts / 168V (1.4V max NiMH voltage * 120) = 0.35 Amps
That's about the same as the grid chargers here (although they run at higher voltage). With losses, figure 0.25 A
To charge the battery, you want to apply about 5 ah (amp-hours), so it would need around 20 hours. Depending on where you live, that might take 4 sunny days.
To put it into perspective, the car can charge that much in six minutes and discharge it in three (at 20 bars of assist).
