The weather in the UK along with the salted winter road over the last 9 years has started to take a heavy toll on the underside of my three cars, the aluminium bodies are fine but the metal suspension components are now very rusty as are some of the brake pipes.
So I'm starting a restoration project which will invole the total removal off all the suspension components at each corner and the rear cross member. All will be totally stripped down, cleaned blasted and powder coated. During reassembly I want to use the original bolts despite all the dire warnings about damage to the dacron anti corrosion coating etc. So i need a compound to put on the bolts etc which can perform that same function and prevent electrolytic corrosion.
Searching the archive found a reference to Mastinox which seems to fit the bill.
http://www.ppg.com/coatings/aerospac...1/mastinox.pdf
Anyone have any experience with this and or any other ideas for a proven anti electrolytic corrosion /seizure compound.
Coppaslip is very popular here but not sure about it's electrolytic properties.
