Originally Posted by 02insight
i am skeptical as to if it really does any dampening. On my car, the vibration with the IMA or with the IMA switch off are about the same...
Or maybe my IMA anti-vibration system is bad, even though there are no codes or anything...
I agree with this. I see no difference between the pack being on or off. In fact with the pack off, if I keep the revs up, the car is a very good car if a bit underpowered compared to my Jag.
