01 Fuel injector specs - Insight Central: Honda Insight Forum
Old 06-25-2010, 05:06 PM   #1 (permalink)
Question 01 Fuel injector specs
I am just wondering if any one can tell me the flow rate of the manual transmission fuel injectors?
I have them at napa for cleaning right now but the info is not in their book. honda dealer doesn't have the info in their catalog either.
mtgeekman is offline   Reply With Quote
Old 06-26-2010, 07:23 PM   #2 (permalink)
I believe I read somewhere 145cm?, but check with a place like RC Engineering for a good place to get them cleaned and balanced.
If your local store doesn't even know what the flow rate should be, I would probably look elsewheremto have them serviced.
Regards,
Jerry
2004 MT Silver Bullet
West Palm Beach, Fl.
Old 06-26-2010, 10:34 PM   #3 (permalink)
Well, I did call RC Engineering and they told me that they do not have the information.
I called a few different Honda dealers in case one of them had access to info another didn't (different states even)
Also sent a message to Denso asking for info on the model number that is on the side of the injectors. Don't really expect a response from them.
Old 06-27-2010, 10:48 PM   #4 (permalink)
Very surprising about RC Engineering, maybe they just didn't want to be bothered? They are well regarded.
Give a try to LHT in Tampa, Florida. Those are the guys that build the k-sight (stuff a VTEC motor into an insight) as well as do turbo gen 1 insights (they to to bigger injectors, but may know the stock size)! If not, they may have a shop that knows the insight and can do your cleaning and balancing.
If you can get the part number, you might be able to get a cross reference and size them that way.
Regards,
Jerry
EDIT: Here you go, look at post #3:
Fix for that bad MPG and rough stutter at 1800 rpm.
Old 06-30-2010, 11:56 AM   #5 (permalink)
Here's what I found out using the Denso Part number
PN 195500-3840
~140cc/min tested at 43.5 psi @ 3 bar
RC Engineering was able to look up the info based on the make/model of the injector.
