Hi. I'm getting ready to start using my new SB 989 to charge the subpacks and after reading for hours, I think I have gleaned most of the settings from various posts. Here's what I have so far as I advance through the Auto Cycle menu:
1) Mode: Auto Cycle
2) Profile: 1
3) Battery: NiMH
4) Cell: 6
5) mAH:6500?
6) Charge Amp: 5-6 with cooling, 3 without?
7) Discharge: Same as Charge setting?
Cut off-Peak mV: user's manual says 4-5 for initial charge?
9) Cut off V: .9 or 1 ?
10) Cut off temp: not necessary if not using temp probe because there is no place to put it?
11) Trickle-Amp: .35?
12) Time: Anywhere from 20-60 minutes...is this the rest time or trickle time, or both?
13) Cycle: 4?
14) Volt: is this a setting or a display mode?
Thanks for any help in this matter and sorry if I'm repeating questions, but I want to be sure about everything before I start the process. Thanks.
