LED Headlight Bulbs? - Insight Central: Honda Insight Forum
Old 08-31-2010, 12:14 AM   #1 (permalink)
Artric's Avatar
Default LED Headlight Bulbs?
I've seen LED bulbs being sold on Ebay that are H4/9003 and would therefore fit the socket for our headlamps.
Would it be possible to use these, or is that a ridiculous notion because no LEDs put out enough light to drive safely?
Here are a couple of examples:
1. HID Xenon White 68-SMD 9003 LED Replacement Light Bulbs: eBay Motors (item 330450246508 end time Sep-08-10 08:44:38 PDT)
2. 2x Car Fog Lights H4 18 SMD 5050 12V White - eBay (item 260649924749 end time Sep-11-10 11:03:05 PDT)
Otherwise, what HID kits have been used successfully, and what percentage of power savings would be seen over a regular bulb?
Thanks!
14, 47, 80, 113
Old 08-31-2010, 12:24 AM   #2 (permalink)
Go for it if you think your parking lights provide enough light to drive by.
Old 08-31-2010, 11:44 AM   #3 (permalink)
Premium Member
satchel's Avatar
From what I have read the proper retrofit is a custom job costing many hundreds of dollars. I don't believe there is any plug and play.
Old 08-31-2010, 11:53 AM   #4 (permalink)
Aren't HID and LED two different technologies? The first link looks like it is for LED bulbs designed to replace HID bulbs in an enclosure designed for HID's????
I see new Audis with what look like multiple LED lights, so perhaps LED's give adequate light if you use a number of them???
I just found this:
http://www.autoblog.com/2008/05/30/a...led-headlamps/
2006 MT
MIMA w/FAS module
various mods to driver
Old 09-04-2010, 09:13 AM   #5 (permalink)
Artric's Avatar
Wow, interesting!
I am trying to find a source that can give a proper light output rating or test between the two, but have not had any luck so far. Please post back if anyone finds info! I will.
14, 47, 80, 113
Old 09-04-2010, 10:08 AM   #6 (permalink)
Lumens (lm) are the unit of luminosity, which is a measure of how much light exits the lamp. lm/W = luminous efficacy, or how efficiently light is produced. If an LED lamp does not include a lm and a W rating, don't buy it. It's as simple as that.
Again I refer you to: Luminous efficacy - Wikipedia, the free encyclopedia
and remind you that you need about 1000lm for an automotive lighting application (and that 1000lm must be pointed in the right direction. DOT approval would be a good sign that it is), so you'd need about 20W of LED or 10W of high-pressure sodium to accomplish that. Though I don't think HID scales down that well.
Old 09-05-2010, 04:17 PM   #7 (permalink)
Artric's Avatar
What do you mean by high-pressure sodium?
14, 47, 80, 113
Old 09-06-2010, 10:48 AM   #8 (permalink)
Sodium-vapor lamp - Wikipedia, the free encyclopedia
