I had a double DIN trim piece imported from Japan and I received it today. The good news is that I have it. The bad news is that its going to take some creative cutting and attaching to make it fit.
If you want to try to install the trim piece in your Insight here are the part numbers.
This is the double DIN for the the 2000-2003 Insight
77330-S3Y-003ZA
This is the double DIN for the 2004-2006 Insight
77330S3Y003ZB
These are the left and right side double DIN radio brackets.
77255-S3Y-000
77256-S3Y-000
To order go here
Sigma Automotive – Accessories that make your car go cleaner, meaner & greener and contact them to get a price quote.
Here are some pictures so you can see what needs to be done.
Here is the front. The double DIN is on the left and the original is on the right.
Here is the back side.
Here is the radio view.
The top 2 tabs will be OK since they are in the same location as the original. Everything else looks like it needs to be modified.
I think I can cut the passenger sides off of each and JB weld them back to the right spots. Then remove all the tabs that wont fit and finally just cut the bottom out a little where the bottom meets the cup holder area since the Japanese and US cars are not symmetric.
The radio area will have to be cut out and I think I will have to cut a new hole for the 12v outlet.
If anyone has any ideas on how to make this look stock I'm open to suggestions. I wont be cutting this thing up until I do a lot of thinking.
