Hi Folks, I've not been on the forum for a long time. I sold my insight back in 2007 or so, although I regret selling it the two seats were a bit limiting for us.
I've been hankering for an electric vehicle for a long time, but I've finally decided to go ahead and try and build one. An insight body is the ideal vehicle due to its light weight and aerodynamics, however I don't have the funds to buy one to gut for an EV, the 2 seats is a bit of a limitation plus I can use my EV mainly on slow back roads so aerodynamics is less of a concern.
With that in mind I decided on a VW beetle, they are cheap, spare are easily available new and in breakers yards, lots of folks have already made EV's from them and they are relatively light. They are also mechanically simple to work on and made of steel, so easy to work with and weld in things like battery boxes etc.
To keep my costs low I initially was thinking I would use a multitude of large model aircraft brushless motors, 3 or 4 of them with toothed belts to run them in parallel. However they aren't as robust as real EV motors and there are problems trying to get reliable inverters to power them. Model controllers are designed to run propellers, very low current and torque at low rpm and steadily rising with rpms. A heavy EV like the beetle would pull enormous current from a standstill and overload them.
I started to think of other options and thought about the honda IMA motor, its robust and has a reliable controller, they are available on ebay and craigslist etc. The only issue with them is either faking signals to the MCM to use a simple drive signal like the MIMA, or design a controller that will send a drive signal directly to the MDM.
As a fall back position if I can't get the honda controller to work, I can always buy a brushless EV controller, I looked into it and they should work with the honda IMA.
I don't have a bug yet as I want to get my engine and transmission all up and running in my workshop before I purchase one, it might be next spring before I do so. But I did start a blog on my build process. I have a transmission and just bought 2x honda IMA's and controllers off ebay.
Here's my blog link:
Electric bug build
Thanks!
P.S. How do you change a user ID? I don't live in MA anymore, I'm in CA now..
