Back in August my headlight switch died as they so often do. So looking through our forum I found some owners had replaced the switch more than once.
I used the Honda Service Bulletin 04-015 to look up the part number of the switch. The bulletin had the headlight switch kit p/n listed (35012-S3Y-306), that is used for the recall. The kit comes with a connector and one pin with a red/white wire crimped on, and the switch. The funny thing was the kit price was far cheaper than the switch by itself. Even the parts guy was surprised.
Since the replacement switch was not improved and keeps failing, I am going to add a Bosch relay to handle the load instead of the switch. The coil on the relay is about 90 ohms generally and so the load will be far less than the headlights themselves. Bosch relays are $5-$10USD.
When I get done rebuilding this pile of motor controllers I will install the new headlight switch and relay, and post it here and on my blog.
Honda Insight Repair and Upgrade Blog by Mike
Mike
