Pioneer HU to stock antenna plug to small??? - Insight Central: Honda Insight Forum
Old 10-23-2010, 04:18 PM   #1 (permalink)
Default Pioneer HU to stock antenna plug to small???
I have never run into this before. The Insights antenna plug ( male ) is to big to fit into the Pioneer head unit( female )? Do they make an adapter for this or should I just cut it, and cobble it up? Im not sure how important the plugs/shielding is for antenna.
Funny thing is that I had to route, solder, heat shrink about 20 wires for this Pioneer HU for the past 4 hours and this was the only thing that didnt work right to first time. So Im not complaining.
'06 Insight Silverstone Metallic / CVT 62.2 LMPG / Sylvania 9003/H4 / 3M PPF / JC Arm Rest / Pioneer Avic Stereo / Polk DB651s / Hot-Air Mod / Mouse Nest Removed From Blower
Titan is offline   Reply With Quote
Old 10-23-2010, 08:50 PM   #2 (permalink)
Id try these people Parts for 2006 HONDA INSIGHT - photos, charts and more 6131 I know the Fit and new Insight uses a funny connector, but this is the same round one like a banana plug?
Old 10-23-2010, 09:26 PM   #3 (permalink)
No I dont see it on that site. I have found that Best Buy audio department should carry the "aftermarket" to Honda antenna adapter. Ill update this post, when I find out.
Old 10-26-2010, 09:16 PM   #4 (permalink)
Default Pioneer install
Hmmm.... last week I installed this pioneer with no antenna problems. Yours must be an older Pioneer?
Amazon.com: Pioneer DEH-3200UB CD Receiver with iPod Direct Control and USB Input: Electronics
av6s2k is offline   Reply With Quote
Old 10-27-2010, 07:21 PM   #5 (permalink)
its about two years old. F700BT. I did get it on close out so maybe it was the end of that gen?
