Yet another Hot-Air Mod-used resonator hose - Insight Central: Honda Insight Forum
Old 11-06-2010, 07:25 PM   #1 (permalink)
Default Yet another Hot-Air Mod-used resonator hose
I used 2 inch flexible exhaust pipe from Advanced Auto. The issue I ran into was that this pipe was so stiff it was difficult to get under the battery box and connect to the original 90 degree intake hose. So I saw the unused resonator hose had a better ability to bend at a 90 degree angle. Using it I was able to connect to the exhaust pipe. I can post pics if anyone's interested. Otherwise its just like other posts that route around the back of the engine to the cat cover. My IAT are running at 95 degrees and it 40 degrees today. Ill need to get a little tighter fit at the cat, to deal with the coming MI winter...but Im pleased for now.
Cost $12! Nice!
'06 Insight Silverstone Metallic / CVT 62.2 LMPG / Sylvania 9003/H4 / 3M PPF / JC Arm Rest / Pioneer Avic Stereo / Polk DB651s / Hot-Air Mod / Mouse Nest Removed From Blower
Titan is offline   Reply With Quote
Old 11-07-2010, 09:29 PM   #2 (permalink)
3-Wheeler's Avatar
Cost $12! Nice!
From your description it's hard to tell if you are still using the resonator or not.
Jim.
Old 11-08-2010, 10:07 PM   #3 (permalink)
insight1's Avatar
Jim.
Yes, I agree and some pics would help.
My fill-ups are only gas worth $10 ≈ 2.8 gallons
Keeps the weight low, passing Avr. 175 miles
Worst $10 tank was 50.1 MPG ≈ 140 miles
insight1 is offline   Reply With Quote
Old 11-10-2010, 11:56 AM   #4 (permalink)
Of course there are people interested!
Regards,
Jerry
2004 MT Silver Bullet
West Palm Beach, Fl.
Old 11-12-2010, 06:48 PM   #5 (permalink)
Default Pics
1st pic is looking from the front of the car. The resonator pipe fits tight over the airbox and then loops 180 degrees to the rear of the car ( it looks pinched against the black box, but it actually slides under a bit)and the resonator slips loosly into the exhaust pipe from Auto Zone. Pipe is 2", bendable exhaust pipe with a coupler on the end. I used this because without the coupler the pipe was a few inches short and would slide around under the battery tray area.
2nd pic from driver fender, you can see the hose slid into the coupler/exhuast pipe udnder the battery tray. Yes, you must pull the tray out, or you may damage some of the wires cabling when trying to route the pipe.
3rd pic shows the passenger side/cat with the end of the pipe resting against the cat shield. Do it doesnt vibrate, the battery tray has a pretty tight hold of the pipe.
My IA temps have been running about 80 degrees with 30 degree outside temps. Up to 110 degrees when its in the 70's. My CVT is getting 63 mpg, and im not that conservative with it. Ill add the rad block once temps drop into the lower 20's.
Old 12-09-2010, 06:33 AM   #6 (permalink)
I used 2 inch flexible exhaust pipe from Advanced Auto. The issue I ran into was that this pipe was so stiff it was difficult to get under the battery box and connect to the original 90 degree intake hose. So I saw the unused resonator hose had a better ability to bend at a 90 degree angle. Using it I was able to connect to the exhaust pipe. I can post pics if anyone's interested. Otherwise its just like other posts that route around the back of the engine to the cat cover. My IAT are running at 95 degrees and it 40 degrees today. Ill need to get a little tighter fit at the cat, to deal with the coming MI winter...but Im pleased for now even though it is a used engine
Cost $12! Nice!
Hey, I want to see that. It sounds interesting. I think I'm gonna so interested if I can see it.
eldercaddy is offline   Reply With Quote
