Robert,
I think the intake resonator circuit is also messing with your situation at 2000 rpm.
Several years back I did a "resonator test" right after installing my hot air mod to see if the resonator actually helped the engine at low rpm's (see below).
How to Build a Hot Air Intake
What I found out is that, yes, the intake resonator does help boost power at 1200 rpm's and above until the null at what else... 2000 rpm.
And above this rpm, at about 2300 rpm's or so, again the resonator helps out.
I do like you do, and short shift typically just before 2000 rpm's or so.
Jim.
