Which spark plugs/ - Insight Central: Honda Insight Forum
Old 11-10-2010, 02:02 PM   #1 (permalink)
Default Which spark plugs/
There are a ton of different spark plugs listed for the G1 Insight. Which ones are best for mileage?
Auto Parts and Accessories Catalog - Spark Plug
Geodesiq is offline   Reply With Quote
Old 11-10-2010, 03:06 PM   #2 (permalink)
02insight's Avatar
The insight uses specialized indexed spark plugs. You have to remove your coil-pack, and see what letter is stamped on the block (A/B/C or D), Majority of the time it is usually "B", but its is best to check before ordering them. And you can only order them from Honda. Aftermarket plugs will technically work, but wont be indexed and may have a different kind of tip.
Here is more info about the indexing of the sparkplugs on the insight:
InsightCentral.net - Encyclopedia - Honda Insight Iridium Spark Plugs
Cheapest I have found are from g1parts.com at only $13.96 each. It may sound expensive, but really in the long run it is worth it since these last a really long time.
Here are the part numbers of each plug, based on their indexing:
12290-PHM-A01 A
12291-PHM-A01 B
12292-PHM-A01 C
12293-PHM-A01 D
Old 11-10-2010, 05:09 PM   #3 (permalink)
JimIsbell's Avatar
I bought 6 cheap plugs that were not indexed. Then I indexed them myself and found 4 of the 6 would index at "B" which was what mine were. This cost me a lot less than buying Honda plugs.
Old 11-10-2010, 08:04 PM   #4 (permalink)
mod: Please delete.
Old 11-10-2010, 08:24 PM   #5 (permalink)
Velociraptor's Avatar
Originally Posted by Geodesiq View Post
There are 3 cylinders. How come there are 4 plugs (A, B, C, D)?
I think this will explain:
Velociraptor is offline   Reply With Quote
Old 11-10-2010, 09:15 PM   #6 (permalink)
JimIsbell's Avatar
OMG, do we really need to explain this. With three plugs there could be A Thru Z if you wanted to index them every 12 degrees!!!!
Old 11-10-2010, 09:36 PM   #7 (permalink)
Only if you want to. If not then just shut up. Or isn't that an option for you?
Old 11-10-2010, 11:47 PM   #8 (permalink)
JimIsbell's Avatar
OOOOO, testy too!!! Cummon, it was a strange question.......................................
Old 11-11-2010, 04:53 PM   #9 (permalink)
For the OP, it is suggested that there is about a 90 degree range of coverage of where the plug electrode is to maximize performance/mileage. So 4 plugs cover the 360 degrees.
I don't know that non indexed plugs would lose much, but given how often you have to change plugs (and there are only 3), it is just not that big of a deal to go indexed plugs.
Regards,
Jerry
2004 MT Silver Bullet
West Palm Beach, Fl.
Old 12-24-2010, 08:57 AM   #10 (permalink)
What tools (i.e. sockets) do I need to take off the engine cover and coil packs to find out which letter I need for the spark plugs? Since I've never done this before, how long should I expect to need to do this?
Roen is offline   Reply With Quote
