Originally Posted by Geodesiq
While installing a charger I attached the pack charge wires to the fan by accident. Can I assume it's fried? Is there a way to test it? If necessary is there a generic substitute?
If you powered up the charger while connected, I would say the fan is fried....
The fan is easy to test just by connecting the proper wires.
If by miracle the fan still works....Don't relax yet....
The fan may be the least of your problems. Since it is tapped into the original fan wires, I would worry more about the controller that turns the fan on and off.....They tend to be expensive. I doubt Honda would have placed any protection into the fan circuitry to protect someone putting very high voltage across the fan.
You would need to see the fan work on its own (in its stock condition - no additional hardware attached) to know if everything is still ok. If you drive around with a blown fan control circuit, the fan will not come on when driving around if the batteries are getting warm and may overheat causing another problem.
Ron at hybrid battery repair may be able to help with replacement parts.
