Originally Posted by TRI
...and Auto-stop is far less than in warmer climate. Does the climate control unit take the set inside temp into account and lets the engine runs more often? If yes, any way to cancel it?
Besides some other factors, AutoStop is also based on the outside temp sensor. In order to get more AutoStops in the winter time, you need to move the sensor to the mid engine compartment.
The sensor is located in the front bumper (behind where the front license plate would attach). The sensor is the only thing with wires that goes to the front bumper mid section so follow the wire trail if you can't locate it.
Without cutting any wires to the sensor, I was able to move the sensor and mount it next to the MAP sensor (near mid engine - left of air cleaner).
I made a bracket for it and used the same 10mm mounting screw that was holding the MAP sensor.
You may have to undo some cable ties to get the wiring to be long enough. I did this mod in 2004 or 2005 and has been working fine since.
My AutoStop even works on some of the coldest days (once the engine completely warms up) and I live in New Hampshire
