When the balancing weights start to fly off. When I heard a couple of bang from the wheel wells I thought it was just road debris but when I saw one of the balance weights hanging by a thread I realized what happened. The tires were too hard at 50lbs and when I hit a bump it threw off the weights. Down to 40lbs and the ride is smoother but still pretty rough.
Many people drive with inflation pressures at 50 psi or higher, but I've never read that this causes wheel balancing weights to detach. I suspect that your balancing weights weren't attached very well to begin with. While I drive with inflation pressures of only 44 front and 41 rear, I've never lost a wheel balancing weight in over 10 years.
New Formula Red 05 MT 116784m
60 psi on 4 different insights for over 35k miles combined. Never a problem or thrown wheel weight at all. Get a new installer that knows what they're doing, and uses the correct weights. For the last couple years, I've been using the stick on weights on the inside of the rims, that do not show on the outside (nor corrode the aluminum rims like the hammer-on lead weights do over time.)
Having installed wheel weights myself, I don't see how tire pressure would knock them off because the area around the bead doesn't really expand at all and even if it did, it wouldn't push a properly installed weight off. Sounds like the balance weight was loose.
