Originally Posted by rhall
I wonder if anyone knows if you can mix yellow and orange battery sticks on a 2000 Insight (the one with the Orange sticks).
It would be hard to answer that question without knowing if the stick you plan on using as a replacement matches the
current properties of the other sticks in the pack. If you are replacing a stick that you believe is not within specifications with another that is much better or much worse than the replacement stick, then you may still may end up with an out of balanced battery pack.
Since this is your first post, I'm not sure if you have reviewed the tons of information in this forum and if you are actually testing each stick in whatever method.
Perhaps you could contact Ron at Hybrid-Battery-Repair dot com to figure out what you want to do....He also visits this forum often.
Hope that helps,
