You can check for loss of chemical reactants ... by performing tests on the cells to determine Wh that they will discharge ... and the dV or voltage drop at a given current, SoC, and temperature.
Chemical reactants could be the Anode , Cathode, or the Electrolyte... electrolyte being by far the most common type to loose in batteries ... but it doesn't really matter which one is lost as you need all three in certain ratios for the cell to function properly.
A shortage of any one of the three can result in lower Wh of discharge capacity , and higher internal resistance in the cell.
Sense Wh of capacity and internal resistance both change with different SoC % and at different temperatures , etc.... if you test the cells compared to the others in a pack ... ideally getting ones to match as closely to each other as possible in as many performance characteristics as possible... of course all tests should be done in as close to the same methodology , and conditions as possible... I also recommend at least 3 identical tests of each cell in order to try and weed out statistical anomalies... for Insight battery packs ... I usually myself only went down the 6 cell stick level ... as I only found marginally small benefits from going to the individual cells , but it did increase the work load substantially, for that marginally small benefit.
The cells that test to be significantly different in terms of discharge Wh , or internal resistance, or self discharge rate ... those are the ones you want to remove / replace ... whatever the specific numbers you get for Wh , Internal Resistance, and Self Discharge Rate ... you want the pack to be matched as closely as possible.
Resist the temptation to rely on terminal voltage ... Discharge Wh , and Ohms are much better indicators ... for example ... I've had NiMH cells down to 0.01 V terminal voltage ... but they still took a charge and worked fine ... some with over ~90% of original capacity remaining.
00-MT-I1
