for those I1's with performance mods - Insight Central: Honda Insight Forum
Old 01-09-2011, 11:08 PM   #1 (permalink)
Default for those I1's with performance mods
i have an I2 and like to get a little bit more hp with an intake or maybe a turbo but some mechanic guy i know just told me hybrids have a lot of sensors and adding these things would cause problems in the future...
some of you guys added turbos or intake to your i1's and was wondering if you have ever got any problems??
thanx
Old 01-09-2011, 11:20 PM   #2 (permalink)
No, you can safely add at least 5psi boost with no poroblem.
Old 01-10-2011, 11:35 PM   #3 (permalink)
5psi??
how many hp would that equal??
idk if you remmember but theres a company in japan that made a turbo for the I2, its selling for 3000
would that cause any problems??
i think ill give the car bout 50 hp more im not really sure thou
Old 01-10-2011, 11:41 PM   #4 (permalink)
If a company made it, then thats fine. Its the frankenstein stuff you mix and match you got to watch. They arent going to be in business long if the 3k dollar turbo doesnt deliver performance and causes engine failure.
Old 01-11-2011, 11:25 AM   #5 (permalink)
Originally Posted by cheesie View Post
5psi??
Since 5 psi is 1/3 of an atmosphere, it will increase power by 1/3. That 67 hp engine will have about 90.
gderian is offline   Reply With Quote
