Need Hose for hot air mod - Insight Central: Honda Insight Forum
Old 02-12-2011, 12:13 PM   #1 (permalink)
Default Need Hose for hot air mod
I installed hot air mod about 10 months ago. The hose I used was not very sturdy; made of black paper and aluminum foil. After these few months, the hose has several holes in it.
Anyone have any ideas about where I can get heavier hose? All aluminum would be nice.
2000 MT 146,000 miles
Bought 1/23/2010
randerson0248 is offline   Reply With Quote
Old 02-12-2011, 12:58 PM   #2 (permalink)
freezin4's Avatar
I used the the same hose but wrapped it in aluminum tape. It has held up for nearly two years. I fabricated an attachment to the cat converter by cutting round hole in its shield and pulling an exhaust pipe adapter through it.
Old 02-12-2011, 03:04 PM   #3 (permalink)
ghammerly's Avatar
I recommend aircraft silicon scat tubing, it will last longer than any other type of tubing and it is resistant to temperature extremes while being flexible. It's worth the extra $$.
SCAT AIRCRAFT DUCTING from Aircraft Spruce
http://www.aircraftspruce.com/catalo...at8ducting.php
ghammerly is offline   Reply With Quote
Old 02-13-2011, 10:54 AM   #4 (permalink)
Thanks ghammerly,
I like that hose.
Bought 1/23/2010
Old 02-23-2011, 12:44 PM   #5 (permalink)
Ryan_C's Avatar
Is the correct Inside Diameter (ID) = 2" ?
I measured mine about a month ago in hopes of coming across a flexible pipe, but no luck yet. Also thanks for posting up, it would have taken me quite some time to figure out what would work best.
Ryan_C is offline   Reply With Quote
Old 02-26-2011, 04:05 PM   #6 (permalink)
ghammerly's Avatar
I don't know, you will have to measure again to determine the correct size of hose to use.
I don't have an Insight yet.
Old 02-27-2011, 09:37 PM   #7 (permalink)
2" is correct.
