Originally Posted by InsightGirl
--The Honda Dealer in Albany tried to put it on a charger and it wouldn't charge beyond 4 bars....
I'm not so sure that the Honda dealer actually charged the HV battery in this step. Getting to the HV terminals requires taking a large sheetmetal panel off the rear compartment and getting to the HV terminals.
The trickle charge itself would take many hours to complete if done properly.
It's almost as if you are referring to the 12 volt battery and trickle charging that.
--I unplugged the battery terminal to reset the computers based on advice from another forum here. It recharged up to a max of 4 bars and then the background charging stopped....
I think you are referring to the 12 volt battery terminal, and yes unplugging that should reset the BCM so that it should again try to top off the HV battery pack.
Why the State of Charge (SOC) indicator on the dash is stuck at 4 bars does sound odd to me, since I have never heard of that before. Resetting the BCM should take care of this.
When you disconnected the 12 volt battery ground and reconnected it, can you point out step-by-step what you saw on the dash?
For example:
1) I unplugged the 12 volt battery cable for 10 seconds
2) Put it back on
3) Turned on the key and the SOC showed nothing, i.e. no charge
4) Turned on the engine
5) Saw that there was a 4 bar background charge occuring
6) Waited approx. two minutes
7) The SOC started to rise
The SOC topped off at 4 bars (never heard of this before) is it even possible?
9) After the SOC stopped rising it settled at
blank bars
Can you run the above steps exactly and report back what you find?
Jim.
