LED lights upgrade - Page 2 - Insight Central: Honda Insight Forum
Old 03-29-2011, 01:40 PM   #11 (permalink)
3-Wheeler's Avatar
For an example of what the LED lights look like on the tail, take a look here:
Honda Insight Tail Extension Project - Page 28 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
Scroll down through the various pictures to see the lights.
Not sure why the lights work well after reading JoeCVT's comments about how the car is wired, but everything seems fine.
I like the fast response time of the LED's and they are much more energy efficient.
Jim.
Old 03-31-2011, 09:12 PM   #12 (permalink)
TheForce's Avatar
I'm currently upgrading my Prius to all LEDs and I want to do the same with the Insight while I'm buying them. If there is no issues with the Insight I think I will upgrade it all around.
2000 MT Insight New Formula Red Picked up 2010/07/23
2000 MT Insight New Formula Red Picked up 2012/01/13
2006 Prius Barcelona Red Package #7. Picked up 2006/01/02
Converted to Plug-In on 2008/08/12 with Hymotion L5
For a list of my mods visit http://www.jaygroh.com
TheForce is offline   Reply With Quote
Old 03-31-2011, 09:43 PM   #13 (permalink)
Blue-Civic-Hybrid's Avatar
Try this link...
http://www.sylvania.com/ConsumerProd...RG-Results.htm
2000 Insight MT= NOW at 100k!!
Old 03-31-2011, 09:54 PM   #14 (permalink)
Originally Posted by Blue-Civic-Hybrid View Post
Server Error in '/Sylvania' Application.
Object reference not set to an instance of an object.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]
Sylvania.Templates.Detail.AutoReplacement_Results. Page_Load(Object sender, EventArgs e)
System.Web.UI.Control.OnLoad(EventArgs e) +67
System.Web.UI.Control.LoadRecursive() +35
System.Web.UI.Page.ProcessRequestMain() +772
Version Information: Microsoft .NET Framework Version:1.1.4322.2443; ASP.NET Version:1.1.4322.2470
2006 MT
MIMA w/FAS module
various mods to driver
Old 04-01-2011, 04:05 AM   #15 (permalink)
Try starting back here.
OSRAM SYLVANIA - Replacement Guide - Start
Just noticed that 2000 Insights aren't listed, but 2001 were.
Old 08-01-2011, 01:07 AM   #16 (permalink)
New to the party
LED brake lights will work, I have them, they work great and the regen works like it always did.
Brake LED How To
I also upgraded all the rest of the lights to LED too with the exception of the headlights. I used the bulb finder at superbrightleds.com
LED bulb finder
They don't have 2000 listed for the insight, I used 2001 and got all the right bulbs.
I also outlined what is needed for making the LED blinkers work.
Turn Signal How To
interestedguy is offline   Reply With Quote
