I'll try and bring some wire as well.
Remember to seperate the wire ends slightly and insulate them from each other at the ipu compartment end so they don't short out in meantime.
Also make a note of which wire/colour in your wire you have connected to which wire at the ECM we need to know that come install day!
Leave plenty of wire spare so you can mount the switch and lcd where you want.
Name I hadn't even considered it but am open to ideas.
Just tried some modified speed sensing code and cruise tweaks it's much better, almost useable now, just need to tweak the calculations a bit more as IMA display is lagging slightly behind oem speed by a second or so.
I had another idea about mounting the switch, how about on the end of the indicator or wiper stalk. I reckon you could dremmel the end out and recess it in there to give a little knob on end of the stalk. Use some very fine wire and route it through stalk into steering column cowling. I might try that as another option. We won't be doing any steering wheel switch installs on the day it's too fiddly. Think about where you want the switch.
The easiest places will be gearstick cowling or steering colum cowling.
Don't forget gaffer tape, epoxy glue, glue gun, sticky pads etc to help you mount switch in choosen position. Switch pdf here for dimensions etc. Hole size etc.
http://www.farnell.com/datasheets/85573.pdf Ours is photo 3.
You need a little wooden knob for the end of it.
Currents are negligible. Use the thinnest wire you can get.
