Subwoofers where the rear cargo cubby is? - Insight Central: Honda Insight Forum
Old 05-15-2011, 10:09 PM   #1 (permalink)
Default Subwoofers where the rear cargo cubby is?
Hello,
Has anyone ever built a subwoofer box that fits on the ledge where the Styrofoam door folds down?
There are many options:
  1. Create a removable, enclosed box that replaces the grey felt insert. It would sit on the same tabs that the foam lid uses.
  2. Create a box that fits inside the grey felt insert. This would let the foam lid close all the way for a stock look.
  3. Remove the grey felt insert and mount the subwoofers to the foam lid and let the entire compartment below serve as the "box"
  4. The same as the above, but with a MDF shelf in place of the lid.
I'm especially interested in the last 2 options. Subwoofers love large boxes and using the entire under-deck area as your enclosure would be a great usage of space. Some sealing would be required. Also, with option 4, the assembly could be removed and stored while taking minimal space.
Thoughts? Unless someone here brings up a reason why it would damage the car, I'm going to try the shelf idea. I found a BBS where the legendary John Wayland was talking about this. Might even try to run a port up to the center console area. I love hacking things.
Thanks
2004 Silver MT #289 "The Aluminium Dominium"
42k miles, between 55 and 85 MPG depending on road rage
Best tank: 76.6 MPG over 710 miles
mct75 is offline   Reply With Quote
Old 05-18-2011, 10:25 AM   #2 (permalink)
racer26's Avatar
John Wayland built the "Shoebox Sub" and "Super Shoebox Sub", which both live under the felt liner of the cargo box, off to the right side there is a bit of room, enough for a properly sized 8" sub in box. My car has one.
Old 05-18-2011, 12:23 PM   #3 (permalink)
Premium Member
satchel's Avatar
Contact Expertfabricator. He has made sub enclosures for others on here.
Look in new posts, his thread has been revived.
New Formula Red 05 MT 116784m
Ad Astra per Aspera
Old 05-22-2011, 02:57 PM   #4 (permalink)
I'm more interested in using the entire trunk area as the "box" as opposed to fabbing one similar to the shoebox. I saw where someone did it with an 8" sub, but it was back in 2004.
Old 05-22-2011, 03:11 PM   #5 (permalink)
I have got an enclosed 8" subwoofer (Alpine SWE-1000) - which fits nicely in the space to the right of the OEM storage box. Best of both worlds.
2005 Insight, UK Spec Silver 5 speed with Alpine stereo, subwoofer & speakers with iPod link, IMA C&C, Shark Fin Aerial, Garmin EcoRoute HD, Skinz sound deadened rear shelf, 'InsightCentral' number plates, 19" rear wiper, Osram nightbreaker plus bulbs
Previous owner of 1999 Japanese Silver 5sp, 2001 UK Citrus 5sp & 2000 Japanese Red CVT
The Citrus Smoothie is offline   Reply With Quote
Old 05-23-2011, 09:45 PM   #6 (permalink)
I'm really looking for the thunderous bass, and particularly the idea of using otherwise wasted space in the whole of the trunk as opposed to the "shoebox" area. When I manage to get my oil changed, this will be my next project.
Old 02-07-2012, 08:25 PM   #7 (permalink)
Send a message via AIM to snowboardsteez Send a message via MSN to snowboardsteez
Default Super Shoebox Sub for Sale
I recently lost my 2000 Insight due to accident. I was able to save all of my electronics & I have my used but in perfect working condition Super Shoebox Sub made by John Wayland. I am interested in selling to another insight owner. Contact me at (860) 917-3389 if you are interested and I will send pictures.
Thanks,
Josh
00' Silver 5 speed Insight 93k
snowboardsteez is offline   Reply With Quote
Old 02-08-2012, 12:22 PM   #8 (permalink)
How about an under seat Sub?
