Rivets and clips front windscreen - Insight Central: Honda Insight Forum
Old 06-23-2011, 11:45 PM   #1 (permalink)
Default Rivets and clips front windscreen
UK insight on e-bay
Bumped it from here since wrong section and no reply and I am almost on the verge to order a new windscreen, any thoughts.?
Originally Posted by Mark Elvin
Welcome to the family.
When looking for parts my first stop would be here ..... 2000 HONDA INSIGHT Original Honda Parts from Lings Honda
I've recently found many of the plastic rivet type fasteners are available on EBAY.....
honda clip 10mm | eBay UK lip+8mm&_osacat=0&_trksid=p3286.c0.m270.l1313]honda clip 8mm items - Get great deals on Vehicle Parts Accessories items on eBay UK!
honda trim clip items - Get great deals on Vehicle Parts Accessories, Wholesale Job Lots items on eBay UK!
dear all I am abit confused about what clips too order for the windscreen
As far as my knowledge of the diagram
Enlarged Image
There are only 4 clips to order am I right? Item 5x2and 6x2
6 PFKL1013541 FASTENER A, WINDSHIELD £7.26 (€7.99) ($11.62) 002
7 PFKL1013559 FASTENER B, WINDSHIELD £4.49 (€4.94) ($7.1 002
Is it because during the removal they are gonna break some from the trim? If so which rivets should I order from the eBay links ? Thank you.
Suntory1980 is offline   Reply With Quote
Old 06-24-2011, 02:19 AM   #2 (permalink)
Here are two pics from the manual.
As far as I remember you need the below plastic clips for the two A pillar trims
www.solarvan.co.uk/insight/RoofMolding1.jpg
A x 14
B x 2
C x 2
F x 2
D & E can be reused if bent gently back into place. Also they are riveted on which is a pain anyway.
For the Cowl you need
www.solarvan.co.uk/insight/Cowl.jpg
A x 7
C x 6
D x 1
Make sure whoever does the job for you has them all before they start, or you will be cursing!! They can be ordered from Ling Honda or your local dealer. I suggest you also look at the e-bay clips and if any are suitable get those by all means. They are not cheap so be warned!! I can't gaurantee you will need them all but it's best to be prepared.
http://www.hondaoriginalparts.com/ho...block_03=19734
I think they were over £70 when I bought some. I have heard of people using silicone to stick it back on.
Old 06-24-2011, 06:59 AM   #3 (permalink)
Kevin Dougherty's Avatar
there are some pictures here and further parts info... posts # 91~96
Good luck and take some more pics.
Wet Seatbelt
kevin
Old 07-05-2011, 12:07 AM   #4 (permalink)
Re the windscreen from the scrap car, we were unable to get it out without breaking it's in the bin!
Old 07-23-2011, 07:56 PM   #5 (permalink)
thanks for your effort RETEP,
BTW I found some good deals for the clips, can anyone confirm if these compatible with my insight? (these sets are from a HONDA CRX )
anyone have a good eye which ones are compatible?
Old 07-24-2011, 12:02 AM   #6 (permalink)
None of the clips in that pic are anything to do with the windscreen on an Insight.
