Ahh. Yeah, being conservative on the voltage of the charger would be a good way to mitigate things. I have my 350mA charger set to 176V after the diode drop.
Regarding the cooling of the battery... yes, I think the whole setup just sucks. I recently ordered a Honda Civic Hybrid battery blower. I'm going to attempt to re-work the entire battery cooling system on the Insight. Both to increase air flow and to change the air source. In my experience it is always hotter in the cabin than outside(I never use A/C). I want to be able to draw air from either the outside or the inside, my choice, depending on the temperature of everything; outside temp, inside temp, battery temp, etc.
I plan to reverse the flow of air and have it pull cool air from outside through the pack and exhaust it next to the passenger seat for the summer months, and having it closer to stock for the winter months, with the option of bringing frigid winter air through the pack if it begins to heat up.
