passenger side water leak - Insight Central: Honda Insight Forum
Old 07-29-2011, 08:34 PM   #1 (permalink)
Default passenger side water leak
Whenever it rains hard or i wash my car...it seems the passenger side seat always gets wet and has temporary stains until i clean it.
Is this is a common problem for Insights? I tried sealing it before where I thought the leak was, but it didn't fix the problem
cah155 is offline   Reply With Quote
Old 07-29-2011, 08:38 PM   #2 (permalink)
It's unfortunately a fairly common problem. Just do a search, there's lots on it.
"wet seatbelt" etc.
Old 07-30-2011, 12:40 PM   #3 (permalink)
thanks I will check it out!
Old 08-06-2011, 12:36 PM   #4 (permalink)
There is a clip under the trim that runs up the side of the windshield and to the back of the door. The clip has a rubber gasket and is right above the seat belt mechanism. You probably need to remove the trim piece and replace the last big clip with one that has a new rubber gasket. It is just a bad design.
Old 08-15-2011, 06:03 PM   #5 (permalink)
any idea what that part number is?
Old 08-15-2011, 09:59 PM   #6 (permalink)
I believe the part you are looking for is "F" in the diagrahm: http://i43.tinypic.com/drb2o5.jpg
Clips Required:
14 pieces of clip A (# 33) Part Number: 91503-S3Y-003
2 pieces of clip B (# 34) Part Number: 91504-S3Y-003
2 pieces of clip E (# 35) Part Number: 91505-S3Y-003
2 pieces of clip F (# 3 Part Number: 91511-S3Y-003
Honda parts site:
2000 Honda Insight Molding, 3DR DX (A/C) KA 5MT B__4210
