Originally Posted by retepsnikrep
Have you done some searching on here for lithium packs and conversions? There are several threads and hundreds of posts. There are also a few people running parallel stock packs which is much easier and cheaper. Again there are lots of threads and posts on this subject.
You need to do some serious reading and then come back to us. Can you give us some background on yourself. Do you have an Insight? Where are you located? What skills experience do you have in dealing with these cars/electronics etc.
In answer to your questions. IMHO of course.
Not directly. Keep the chemistry the same.
You could add a buddy pack which keeps the stock pack charged via a DC/DC converter. At least one person has done this with an engineer lithium system.
Depends on how you are going to do it.
Nominal pack voltage of the stock pack is 144v. Max system voltage is ~190v. Lowest resting voltage is ~140v. Under load it can drop to around ~120v
Hey
yes, i've been reading some posts; on how to modify/service... alot of reading ahead of me, i'm just anxious to get the ball rolling on my project
i will update my sig to refect my car info
I have great skills in repairing/building/modify electic bicycles!
Please search my username on youtube -- trdfreak03
I have lots of videos on my high power electric bikes, my current bike is
20kw+
88.8v 24s 1p pack @ 200amps + on a crystalite x5 hub motor..20kw +
I've also have experience assembling many brushless hub motor controllers/repairing brushless motor hall sensor, upgrading wire gauges for higher power/ ah ... amps of my batts... list goes on ... i'm really sabby on the ebike end ... not so much on the insights
i will search some posts on how to increase battery capacity, thanks for specifying the voltages needed!
-steveo
