Gas Vapor system - Insight Central: Honda Insight Forum
Old 08-13-2011, 10:38 AM   #1 (permalink)
Default Gas Vapor system
So I watched a movie called Gashole yesterday and they showed a system that Tom Ogle built back in the 70's that will run a car on gasoline vapor instead of liquid fuel. The system make a standard engine run up to 5 times for efficient. Given that our motors are lean burn and already can run 25:1 a/f it wouldn't be 5x improvement. Without lean burn we can get roughly 45-65 mpg? So 150-250mpg?
Has anyone else seen this technology before?
N2oExpresS2k is offline   Reply With Quote
Old 08-13-2011, 10:59 AM   #2 (permalink)
madmanmostafa's Avatar
Send a message via MSN to madmanmostafa
The car runs on vapor. The injectors atomize the fuel to make them more of a gas so they combust. Gas as a liquid is not flammable. It's the vapors. Correct me if I'm wrong, though.
madmanmostafa is offline   Reply With Quote
Old 08-13-2011, 11:23 AM   #3 (permalink)
EFI doesn't turn gasoline to vapor, it turns the gasoline into more of a mist. Gas vapor systems use a jar with gas at the bottom and inject hot exhaust into the gasoline to vaporize it, that vapor is carried from the top of the jar to the intake where the engine will burn it.
It's pretty difficult to find any good info on the technology though.
Old 08-13-2011, 09:14 PM   #4 (permalink)
This "technology" exists in the same realm as cold fusion, water powered cars, and the secret anti-gravity spy plane built in Area 51 with a little help from the Grays.
Basic science debunks it. There is only so many molecules of hydrocarbons in fuel to combine with so many molecules of oxygen in the air, thermodynamically producing a certain amount of power. Believe me the fuel is already fully vaporized and combusts pretty damn efficiently in the Honda engine.
ackattacker is offline   Reply With Quote
Old 08-13-2011, 10:00 PM   #5 (permalink)
I agree Honda did an excellent job with the insights drivetrain. I'm sure there's more to the fual vapor tech than it just being a fuel efficiency myth though. Doing more research on it, it seems that it's biggest draw back comes from the added NOx which honda addressed when they implemented lean burn in our car. Either way, I haven't found anything that shows bigger gains than our lean burn gives us.
Old 08-13-2011, 10:48 PM   #6 (permalink)
IamIan's Avatar
Developed into a functional vehicle and competed in the X-Prize ... even combined with a custom built energy efficient vehicle , they lost ... other methods achieved better mpg... and this method allowed for up to 20:1 Air to Fuel Ratio's ... our Gen-1 Insight's , can operate more lean than this.
Link
5x improvement ? no ... not possible.
The OEM Insight ICE even outside of lean burn can operate at more than 38% efficiency Chemical energy input to Mechanical Energy Output... BSFC chart under full throttle testing ( not in lean burn ) peaks out at ~200 g/kwh ... ~76.9 g/kwh = 100% efficient gasoline ... 76.9/200 = over 38% Efficiency... 38x5 would be 190% efficient = not possible.
Given that the most Efficient ICE I've ever heard of ( the The MAN S80ME-C7 ) peaks out at about ~54.4% efficient ... compared to our over 38% ... and that is not nearly so simple to get to ~54.4% efficient ICE.
There are many areas of improvement , but large increases in ICE efficiency is not one of them... look to things like better aerodynamics , lower rolling resistance, waste energy recovery, better driving techniques, etc.
00-MT-I1
Old 08-14-2011, 12:00 AM   #7 (permalink)
Great info Ian, thanks for the bsfc numbers. Is it possible for the bsfc test to be performed with lean burn accounted for, or is that something that is typically done at wot?
Old 08-14-2011, 12:49 AM   #8 (permalink)
The next step will be "Direct Injection"........some of the new cars have it now.
(My opinion)
Old 08-14-2011, 12:50 AM   #9 (permalink)
Direct Injection is huge on MPG and overall performance. I mean diesels have been using it forever. Recently GDI has been popular on performance cars, and now Hyundai has slapped it on their cars and have had tremendous results. If they developed a tiny 3 Cyl GDI motor that fit in the insight, it could be a great replacement. Their tiniest 1.6L 4 cyl GDI engine produces 139HP
Old 08-14-2011, 07:16 AM   #10 (permalink)
IamIan's Avatar
Yes it is possible to account for Lean Burn in a BSFC chart ... yes the BSFC is typically done at WOT ... which is how the BSFC chart ( attached bellow ) for the Gen-1 was done ... sense the OEM Gen-1 Insight will not enter Lean Burn anywhere near WOT , lean burn operation is not shown in that BSFC ... It is my wish list of things to do eventually ... unfortunately there are some complications.
  • Requires a chunk of dyno time which is expensive... and a chunk of time.
  • Average dynos do not have the means to do it... you have to:
    • Find a better dyno with the means ... or
    • Brings the additional the dyno is missing with you to an average dyno... or
    • Setup your own dyno with the means.
The Average dyno gets most of their dyno time money from the 'high power' market ... not the high efficiency market... which means:
  • Some are just plain not interested at all ... I've had some rude comments , some outright refusals ( "not in my shop" ) , some have even stopped communicating email or hung up the phone on me as soon as they realize it is energy efficiency testing and not some 500+ HP seeking muscle car driver.
  • Even if you find one that is willing ... and you have the time and money ... you then need to figure out how much of the test equipment needed they have and how much you have to provide and operate yourself... Things you will need:
    • Accurate fuel rate measurements ... how many grams or milligrams ( or liters or milliliters ) of gasoline per second or millisecond... have to quantify exactly how much fuel you are using , at what rate , and know what your error rate / accuracy is.
    • Accurate fuel energy content measurement ... Gasoline as a mixture varies in energy content ... it averages ~13kwh/kg or ~9.7kwh/L but it can vary by more than 10% +/- depending on the specific mix you have on hand... that is too large or a variation for reasonably accurate energy efficiency testing ... and a more accurate energy content determination of a specific batch of gasoline would have to be determined to get the error rate way down from +/- 10%.
    • Accurate Air to Fuel ratio measurements for the range larger than the Gen-1 Insight is able to run at ... Some people who have tested the Gen-1 Insight ICE with better AIR Ratio meters have seen as high as 25.8 to 1 Air to Fuel Ratios ... this is unique enough that many dynos just can't measure that lean.
    • Accurate engine power output at lower power numbers than some dynos are calibrated for... we have a peak ICE of ~67 HP at the peak power point ( not the same point as peak energy efficiency ) and that is under Rich Burn conditions ... ( I've seen some reports of tests measuring it as Rich as 12.5 to 1 Air to Fuel ratios ) ... that is in the range of 1/2 the fuel rate in LB vs RB ... even with some efficiency benefits to LB we are looking at a dyno that needs to accurately measure power output well bellow 30 HP ... given the Power output graphs at WOT I've seen ( attached bellow ) we may need to go as low as ~5 HP.
The above is doable ... just needs time and $ ... what I would expect to see in general is a BSFC chart that changes with A/F ratios , V-Tech on or off , and our variable Ignition Timing, variable throttle losses ... I would expect a shift of the higher efficiency areas toward lower RPMs... and a bit of a jump at the line where the V-Tech goes into or out of LB , and into or out of RB.
The reduced friction would be an efficiency benefit but the throttle losses would reduce efficiency ... so I would expect the final OEM performance of highest point peak efficiency not to be much higher than OEM ~38% without modification to a un-throttled engine ( no small task ) ... but I would expect that higher efficiency area to grow in size and move to different Torque / RPM points as the engine kicks into and out of Lean Burn Mode ... and while in LB-Mode as our variable ignition timing changes and as the A/F ratio changes... Lean air to fuel ratios burn slower and our variable ignition timing advances some to compensate for this.
Oh ... one more thing ... if the IMA is attached during the test ... ideally it wouldn't be ... you have to compensate for any power / energy it adds from the battery ... something like MIMA could be used to remove almost all the IMA power/energy flow ... But a voltage and current sensor on the IMA motor outputs could be used to confirm it is close enough to Zero , or to quantify the IMA contribution to allow for it to be compensated for... otherwise if you are reading the voltage and current at the battery you are ignoring buffer capacitor effects and you have to compensate for the efficiency of the IMA system.
(My opinion)
Perhaps.
Although I see more room for improvement to be had in the waste energy recovery area ... even direct injection even at it's peak efficiency still throws away about half of it's fuel energy .... the most efficient ICE I've seen is only ~54.4% efficient ... and is still throwing away almost half the chemical energy in the fuel ... from ~38% to ~54% is only ~16% improvement ... vs our ~62% waste energy to ~46% waste energy ( at the ~54% point ) ... It just looks to me like there are just larger gains ( more energy ) to be had in the waste recovery area... although I'd be happy to take both
00-MT-I1
