OBDIIC&C Gauge - Page 268 - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 05-17-2017, 02:40 PM   #2671 (permalink)
eq1
eq1's Avatar
The next version of OBDIIC&C firmware will have an IMA subcode display option in the IMA section.
That will be very helpful...
2000MT, CAN, ~168K miles
Old 05-19-2017, 12:05 PM   #2672 (permalink)
Default OBDIIC&C MCM DTC IMA Subcode Display
This test version 12 dated 190517 now has the IMA error subcode display upgrade.
From the IMA mode submenu.
Pressing up now displays the stored IMA error codes in detail with subcodes.
https://youtu.be/JQ3TE-qh6s0
Youtube video above..
Without going into too much techy detail it appears quite an interesting MCM error code hierarchy is going on..
Each dtc memory locations can hold two codes, but it appears not both at the same time????
I need to do a bit more work on this to confirm but it's weird..
File Type: hex ODBIIC&C_&_IMAC&C_18F2620_32mhz_V12_190517.HEX (117.4 KB, 17 views)
Pcb's/Built Units for ObdIIc&c, Imac&c, ImaBoost, Current Hacks available. Enqs to 150mpg[at]gmail.com
retepsnikrep is offline   Reply With Quote Quick reply to this message
Old 05-20-2017, 07:28 AM   #2673 (permalink)
Peter,
Is this active on the latest version?
Left AFaOff/On Auto bat fan mode (Not currently active). This mode will turn the battery fan on at lower temperatures than the standard system. It is useful for those in hot climates and avoids the user having to manually intervene each time they want the fan on
Sam12345 is offline   Reply With Quote Quick reply to this message
Old 05-20-2017, 02:20 PM   #2674 (permalink)
Sam12345 No it's not.
However what temp would you want it to activate the battery fan?
I was thinking below 20C fan off, above 25C turn fan on low, above 30C turn fan on high..
Making it user adjustable at the moment would use a fair bit of memory so just give me an idea of the temp you want..
It will remember the setting between drives so the fan will run automatically as soon as you start the car the next time if the temp is above the limit we choose.
Old 05-20-2017, 04:30 PM   #2675 (permalink)
Rainsux's Avatar
With our summer temperatures (not as hot as El Paso) I just turn it on High and let it run all summer.
Sam
2000 Citrus
Custom Turbocharger System
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
NM license plate KERS
Alpine Stereo
GAZ rear shocks
Rainsux is online now   Reply With Quote Quick reply to this message
Old 05-20-2017, 06:05 PM   #2676 (permalink)
Yes but you got to turn it on high every time you start. I would rather set it and firget it. I would say 90F Peter
Old 05-20-2017, 06:09 PM   #2677 (permalink)
Yeah 25 C low 30C high sounds good.
Old 05-20-2017, 07:06 PM   #2678 (permalink)
Rainsux's Avatar
No. It stays on until I reset it in the Fall. Maybe we have a different software version or something.
Sam
2000 Citrus
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
Alpine Stereo
GAZ rear shocks
Old 05-20-2017, 09:41 PM   #2679 (permalink)
Mmm i wonder why mine resets
Old 05-21-2017, 03:19 AM   #2680 (permalink)
I'll re-implement the auto fan option with the next version..
Random Question
