Installing engine air filter... which way is up? - Page 2 - Insight Central: Honda Insight Forum
Old 02-05-2012, 01:47 PM   #11 (permalink)
Not a big fan with the K & N Filter for this vehicle. I installed one in mine and used it for about 30 miles or less; I was averaging around 8-9 MPG less over a paper filter.
TrevorInsight is offline   Reply With Quote
Old 02-05-2012, 02:15 PM   #12 (permalink)
Air cleaners will only effect your mileage IF it is restricted. There are both pros and cons about using a K/N filter. It all boils down to owner preference.
Old 02-05-2012, 02:21 PM   #13 (permalink)
Can you explain the differnce in fuel economy I was experiencing?
Old 02-05-2012, 02:35 PM   #14 (permalink)
Nope, I wasn't there to witness how you drove. Not to be sarcastic but there are to many variables to say that the filter was the cause of the loss in mileage. Once changes are made, the ECU has to adjust to those changes, so it will take several "drive cycles" to make that happen. I don't think it can be done in 30 miles.........My opinion.
Maybe at the next AZ meet, we can devote some time to different scenerios for testing.
Tags
air filter, engine air filter
