OBDIIC&C User Manual - Insight Central: Honda Insight Forum
Closed Thread
Old 01-14-2012, 07:24 PM   #1 (permalink)
samwichse's Avatar
Default OBDIIC&C User Manual
I just thought this topic deserved its own thread.
Edited by Peter, Thanks Samwichse I have incorporated those notes you posted into my post below.
samwichse is offline
Old 01-15-2012, 01:52 AM   #2 (permalink)
Default Obdiic&c v0.02 Manual
This thread is soley for the OBDIIC&C manual, please post questions in the main thread at OBDIIC&C Gauge
This post is for software release V0.02, new versions of the software will have seperate posts in this thread.
What's new?
Parameter selection is enabled.
Pwm backlight is enabled.
Scangauge nomenclature is used.
New config sub menu
Added alarm sound toggle
Added switch beep toggle
Data logging ouput is now 4hz
Background Ah/Wh counting and IMA data sampling is now 4hz
EGR test mode added
Battery IR calc added
Watts display added
IMA Lcd display update is now 4hz
12V Aux battery voltage display added
When you first power up the gauge and plug it in you should get the message below.
If you don't, goto the troubleshooting info at the end of this post.
Each button press and menu option is now described please read it all carefully.
"Waiting for OBD Port" Message when starting.
Push & Hold = Config Sub Menu. Only use this when bench testing or if the gauge wakes up in error when ignition is off.
Main Screen Main 8 parameter display screen after correct gauge startup.
Up = OBDII Mode
Down = IMA Mode
Left = Parameter Selection Mode
Right = Ah/Wh Mode
Push = Config Sub Menu
The default display settings are
IMA: Left side of screen
15 - TEM Battery temp
0B - VOL Battery voltage
10 - SOC Battery state of charge
12 - AMP Amps in/out
ECM: Right side of screen
04 - LOD Engine load
05 - ECT Engine coolant temp
0F - IAT Intake air intake temp
15 - O22 Secondary O2 sensor voltage
OBDII Mode Displays/Clears OBDII Error codes.
Down = Clear OBDII Error Codes
Push = Main Screen
If there are no OBDII codes stored when you enter this mode the gauge will automatically return to the Main Screen.
Once you have cleared any error codes you should cycle the car ignition on/off to complete the clearing sequence and turn off the MIL.
You should clear the IMA error memory before clearing the OBD codes or they will come back again.
IMA Mode Displays/Clears IMA Error Memory & Soc/Fan Control.
Up = Display IMA Error Memory
Down = Clear IMA Error Memory
Left = IMA Battery Fan Control
Right = IMA Battery Soc Control
Push = Main Screen
Once you have cleared the IMA error memory you should cycle the car ignition on/off to complete the clearing sequence and turn off the IMA light.
IMA Battery Fan Control Allows control of IMA Battery Fan.
Up = Fan Off
Down = Fan On High
Left = Fan On Low
Right = Not used
Push = IMA Mode Screen
IMA Soc Control Allows control/overide of IMA Battery Soc. Use with care!
Up = Set Soc High 19 Bars 75%
Down = Set Soc Low 8 Bars 40%
Left = Set Soc Medium 17 Bars 60%
Right = Not Used
Setting the Soc high prevents/reduces the forced charge mode
Setting the Soc low prevents/reduces the assist available
You can only overide the Soc to a certain point.
If the battery is truly exhausted or completely full then your Soc seting will be overidden by the BCM safeties almost immediately.
Ah/Wh Mode Displays Time/Ah/Wh capacity & Lcd Backlight Control.
Up = Reset Elapsed Time Count
Down = Reset Ah/Wh Count
Left = Decrease Lcd Backlight Brightness
Right = Increase Lcd Backlight Brightness
Push = Main Screen
To conduct a battery capacity test use the Soc reset low feature several times to force charge the battery until no further charge is allowed. Then reset the Ah/Wh/Time display here to zero, return to the main screen, and drive the car reseting the soc to high several times to avoid any charging. Drive using lots of wide open throttle in high gear and lots of assist until no further assist is allowed and the battery is exhausted. Then return to the ah/wh mode and note your figures. Note the gauge currently only counts Ah/Wh when in the main display mode, so only change from the main screen to reset Soc etc when not using assist/regen to ensure data is not missed. Pressing the clutch disables assist/regen so this can help,
Parameter Selection Mode Changes parameters for display on main screen.
Up = Increment IMA parameter
Down = Decrement IMA parameter
Left = Decrement OBD parameter
Right = Increment OBD paramater
Push = Move to next parameter & Main Screen
When entering this mode the parameters for the first/top line of the lcd are displayed as hexadecimal numbers. Use the button to change the numbers to the ones you wish from the available parameters list below. Push button in to move to next line and repeat until all four lines are displayed. Then push button in to return to the main display and save your selection. Just push button in to skip lines if no changes are required.
IMA parameters appear on the left of lcd and OBD on the right. You cannot select IMA or OBD parameters to appear on the opposite sides. Incorrectly selected or illegal parameters will mean the lcd displays a blank at that position when you return to the main screen.
For the lean burn green led to function parameter $15 must be among one of those selected for the OBDII side of the screen.
For the water temperature alarm and red led to function parameter $05 must be among one of those selected for the OBDII side of the screen.
OBDII List Click Left/Right to change
PID = $04 'Engine Load 0 to 100%
PID = $05 'Engine Water Temp -40 to +215C (This drives the water temp alarm)
PID = $0B 'Intake MAP 0 to 255kPa
PID = $0C 'Engine Rpm 0 to 16,383 rpm
PID = $0D 'Vehicle Speed 0 to 255 kmh
PID = $0E 'Timing Advance -64 to +63.5 (Not working correctly yet)
PID = $0F 'Air Intake Temp -40 to +215C
PID = $11 'TPS Throttle 0 to 100%
PID = $14 'O2 Sensor Bank0 Voltage 0 to 1.28V A/F Sensor (Not working correctly yet)
PID = $15 'O2 Sensor Bank1 Voltage 0 to 1.28V (This drives the lean burn led)
PID = $FE 'Melexis Sensor Ambient Temp
PID = $FF 'Melexis Sensor Object Temp
IMA List Click Up/Down to change
PID = $0B 'Bat Voltage
PID = $10 'Bat Soc
PID = $12 'Bat Amps
PID = $15 'Bat Avg Temp
PID = $FC 'HV Insulation Resistance in KOhms
PID = $FD '12V Bat Voltage
PID = $FE 'Bat Internal Resistance IR in Ohms
PID = $FF 'Bat/Ima Power Watts
Config Sub Menu 1 All Config Bits Default to 1
Up = Toggles SCS error blink code mode (Default 1 = Off) (Not on UK Cars)
Down = Toggles Temperature Display C or F (Default 1 = C)
Left = Toggles Speed Display Mph or Kph (Default 1 = Mph)
Right = Toggles +32% Amps Mode Compensation (Default 1 = Off)
Push = Config Sub Menu 2
Do not activate the +32% Amps mode unless you have a modified BCM or the amps display and ah/wh calculations will be off by miles.
Config Sub Menu 2 All Config Bits Default to 1
Up = Toggles Switch Beep (Default 1 = On)
Down = Toggles Audible Alarm Mode (Default 1 = On)
Left = Toggles Data Logging Output On/Off (Default 1 = On)
Right = Toggles Voltage Hack Mode Compensation (Default 1 = Off)
Push = Test Mode Menu 3
Do not activate the Voltage Hack mode unless you have a modified BCM/MCM or the voltage display and ah/wh calculations will be off by miles.
Toggling the Audible Alarm Mode off prevents the gauge using the beep to alert you to Alarm conditions like an engine coolant over temperature situation.
Test Mode Menu 3
Up = 30-60mph 2nd gear acceleration test. Push button to abort
Down = 50-70mph 5th gear acceleration test. Push button to abort
Left = Enter EGR test data logging mode. Push button to exit
Right = Force gauge to go to sleep. Use if the gauge wakes up when car ignition is off.
Push = Main Screen
If the gauge wakes up unexpectedly when the ignition is off and the screen is on displaying "Waiting for OBD port" then press and hold the button until the config menu appears, go through the menus until you reach this one and use the Right press to send it back to sleep.
The acceleration tests should be carried out twice for each parameter, once in each direction on the same stretch of road to eliminate terrain effects. Calculate your average for the two runs and post the results on the OBDIIC&C performance spreadsheet please.
https://docs.google.com/spreadsheet/...hl=en_US#gid=0
The EGR data logging mode outputs the EGR pot value to the logging port so it can be captured via a laptop into a spreadsheet for analysis.
Logging requires a serial to usb lead and excel running the plx-daq software.
Troubleshooting notes
1) If the gauge fails to start correctly when the ignition is turned on, remove and reinsert plug into obdii socket to force a hard reboot.
2) If the gauge lcd has nothing on it check 1) above, followed by the contrast pot adjustment.
Cold weather effects the lcd contrast so minor adjustment may be necessary in extreme temps.
3) If the gauge crashes, locks up, displays incorrect data or exhibits any other unexpected behaviour please report the circs to the forum for investigation.
Programming Notes
From time to time I will release software updates for the gauge, these will include extra features and bugfixes. To update the gauge with the new software you need a pic programmer.
iCP01 - USB PIC Programmer
This post contains details and links to some programming demo videos.
OBDIIC&C Gauge
That's everything for V0.02 of the software. Thanks for your support, I hope you enjoy playing with your new toy.
Peter
retepsnikrep is online now
Old 01-23-2012, 02:49 PM   #3 (permalink)
Default Obdiic&c v0.02 Manual Continued
Manual continued. The post limit of 10,000 characters on IC means this section and other additions will have to appear in this post.
Data logging to a laptop
The gauge by default outputs several IMA parameters to the serial logging port at 4hz 9600,8,N,1.
The logged data is in the format Time, Ima Bat Volts, Amp Sign + or -, Bat Amps, Soc, Bat Temp, Bat Watts & Bat IR. Logging requires a serial to usb lead and Microsoft Excel running the Plx-Daq software.
A sample spreadsheet is included with the Plx-Daq software you will need 9 columns to log the data.
PLX-DAQ Data Acquisition tool
I recommend the Picaxe serial to usb lead.
UK/US PICAXE USB Download Cable (AXE027) - Hardware - PICAXE
Old 03-01-2012, 03:16 AM   #4 (permalink)
Default Obdiic&c v0.03 manual
This post is for software release V0.03.
What's new?
Lots more parameters added to the available selection. (List below)
Added DTC Code check at gauge startup.
Added AFR Air Fuel Ratio display and Lean Burn light control.
Added Vtec Flag on far right of lcd.
Added Bat Fan Flag on far right of lcd.
Added CVT Ratio display.
Added regional software versions to cater for differences bewteen EU/UK & US/CAN cars.
Added Ecm version number display.
Several major bug fixes and enhancements.
Removed IR Calculation. (Not reliable yet)
When you first power up the gauge and plug it in the gauge will display any stored DTC codes or go straight to the main display if there are no codes present.
If DTC codes are displayed you can clear them by pressing Down or ignore them and skip to the main screen by pressing Up Once you have cleared codes you should go to the main display and then cycle the ignition off/on to complete the process. IMA codes are slightly different and dealt with from the main screen at present. Described lower down. You should clear the IMA error memory before clearing the OBD codes or they will come back again.
Up = Restart Gauge and OBDII DTC Mode
Down = IMA Mode
Right = Ah/Wh Mode
TEM Battery temp
MVO Battery voltage
AMP Amps in/out
IAT Intake air temp
AFR Air fuel ratio (Drives lean burn led)
INJ Fuel injector time in ms
Push = Main Screen
Once you have cleared the IMA error memory you should return to the main screen and restart the gauge to clear the DTC codes, then cycle the car ignition on/off to complete the clearing sequence and turn off the IMA light.
Up = Fan Off
Down = Fan On High
Left = Fan On Low
Right = Not used
Right = Not Used
Push = Main Screen
For the lean burn green led to function the AFR parameter must be among one of those selected for the OBDII side of the screen.
For the water temperature alarm and red led to function the ECT parameter must be among one of those selected for the OBDII side of the screen.
All Cars
'Ima $04 = Mdm Amps
'Ima $05 = Mdm Volts
'Ima $08 = Mdm Temp
'Ima $09 = Dc-Dc Temp
'Ima $0B = Bat Volts
'Ima $10 = Bat Soc
'Ima $12 = Bat Amps
'Ima $15 = Bat Temp
'Ima $19 = 12V Bat Volts
'Ima $FE = CVT Drive Ratio
'Ima $FF = Battery Power in Watts = Amps x Volts (Requires Amps and Volts on screen to work)
Eu Cars Only
'Obd $00 = Engine Rpm
'Obd $02 = Vehicle Speed
'Obd $10 = Ect Coolant Temp
'Obd $11 = Iat Intake Temp
'Obd $12 = Map Pressure
'Obd $13 = Bar Pressure
'Obd $14 = Throttle Position
'Obd $19 = Electronic Load Detector
'Obd $1B = Egr Feedback Sensor
'Obd $24 = Fuel Injector ms
'Obd $26 = Timing Advance
'Obd $2E = Primary O2 Sensor Afr Ratio (Lean burn led driver)
'Obd $9C = Engine Load
'Obd $A0 = Secondary O2 Sensor O22 Sensor Voltage (Old lean burn led driver)
'Obd $FE = Melexis Sensor Ambient Temp
'Obd $FF = Melexis Sensor Object Temp
US/Canada Cars Only
'Obd $01 = Vehicle Speed
'Obd $02 = Ect Coolant Temp
'Obd $03 = Iat Intake Temp
'Obd $04 = Map Pressure
'Obd $05 = Bar Pressure
'Obd $06 = Throttle Position
'Obd $07 = Electronic Load Detector
'Obd $08 = Egr Feedback Sensor
'Obd $09 = Fuel Injector ms
'Obd $0A = Timing Advance
'Obd $0B = Primary O2 Sensor Afr Ratio (Lean burn led driver)
'Obd $0C = Engine Load
'Obd $0D = Secondary O2 Sensor O22 Sensor Voltage (Old lean burn led driver)
Status flags These will show when a parameter is active, the current selection is.
Lcd Line 1 IMA Battery Fan shows "F" when active
Lcd Line 2 Vtec Mode Shows "V" when active
Left = Toggles Data Logging Output On/Off (Default 1 = Off)
Right = Resets display parameters to default values
Test Mode Menu 3
Right = Display Ecm version number. Please add it to the module spreadsheet.
Push = Main Screen
Programming Notes
OBDIIC&C Gauge
That's everything for V0.03 of the software. Thanks for your support.
Peter
Old 03-04-2012, 02:36 PM   #5 (permalink)
Dear all.
This thread is locked and will be used by me for OBDIIC&C Manual updates only.
We however have the following OBDIIC&C threads currently running. Please choose the most relevant when posting.
The manual thread, soley for my user manual and instruction posts. Locked!
The main thread for all general queries, questions & comments.
OBDIIC&C Gauge
The performance testing thread and spreadsheet. 30-60 & 50-70 mph times, discussion.
OBDIIC&C Performance Testing
The ampere & watt hour counting thread.
Amp Hour counting with the OBDIIC&C Gauge
The RGB edition and other lcd mods thread.
OBDIIC&C Gauge RGB LCD edition and other modifications
The gauge build notes thread for self assemblers.
OBDIIC&C Gauge Build Notes
The gauge troubleshooting thread.
OBDIIC&C Troubleshooting
The Civic HCH1 version thread.
OBDIIC&C HCH1 Gen 1 Civic Hybrid
Related threads include.
The ECM/MCM/BCM revison thread and spreadsheet which applies to all Honda IMA cars.
BCM, MCM & ECM Revisions
Please review any of these you are unfamiliar with and add data to the spreadsheets as relevant.
The more data we accumulate the better our understanding of the cars will become.
Thanks Peter
Closed Thread
