OBDIIC&C Gauge RGB LCD edition and other modifications - Page 2 - Insight Central: Honda Insight Forum
Old 12-07-2012, 12:59 AM   #11 (permalink)
I can't see any major problem with the parallel version.
Each screen has it's quirks though so no guarantees. You'll have to try it.
OBDIIC&C $50 inc software and blank pcb.
IMAC&C HCH1 Civic $50 inc software and blank pcb.
IMAC&C G1 Insight $105 inc software and blank pcb.
Old 01-21-2013, 04:55 PM   #12 (permalink)
Default OLED vs LCD
Removed the green LCD that I was using and changed to above mentioned OLED. It all seems to be working fine.
Pros:
Clearer display
More efficient (does not heat up as much)
Thinner
Lighter
Cons:
Cost
OBDIIC&C box window too big
Enclosed are pics comparing the LCD with OLED
pascal28 is offline   Reply With Quote
Old 01-21-2013, 05:52 PM   #13 (permalink)
samwichse's Avatar
That OLED does look sweet in there .
Are all the OLED ones that same smaller dimension, or just the one you got?
Sam
-OBDIIC&C
-IMAC&C
-Lower grill block
Old 01-22-2013, 02:26 AM   #14 (permalink)
Looks Nice. I use an OLED in mine as well.
But they are about three/ four times the price of the lcd ones bought in bulk as mentioned.
Old 01-22-2013, 12:54 PM   #15 (permalink)
Lean Burn = Happiness
jeff652's Avatar
Can the screen be connected remotely from the rest of the C&C? I would love to bury everything except the screen under the dash and have the screen thin mounted onto the dash somewhere.
EDIT: Looks like is still has the PCB backing. Is there a screen that would work that has a cable/plug instead of the PCB?
Old 01-22-2013, 01:15 PM   #16 (permalink)
You could use a 16 way ribbon cable.
Need to keep it to less than 0.5m and you might get some interference issues, someone will have to try it.
Over to you guys!
Old 01-22-2013, 01:27 PM   #17 (permalink)
Mark Elvin's Avatar
I've been thinking the same, perhaps using screened cable.
2003 Quantum Grey G1 Insight
83.5 LMPG
25,500 Miles
IMA C&C (to be fitted)
ODBII C&C
Mark Elvin is offline   Reply With Quote
