The desire was for a circulating block heater. Lots of options out there.
Undesirable properties exist in the aftermarket options:
Inline heater in a hose; localized cooking of the hose?
Enormous volume of flow; think big block under load; not for the Insight.
Physical size; need small for real-estate concerns.
Just a few that pointed away from readily available automotive options.
So, lets look at the solar heating hardware.
High temperature rating.
More options with less flow volume.
12v.
Nice possibilities here. Still expensive.
The EL-SID 5PV from Ivan Labs was chosen.
5 watts
2.5 GPM flow. Still quite a lot for 1 gal of coolant, but spec sheet says PV models will run slower on battery voltage. That will be alright.
Light weight.
250F max temp.
No shaft. Magnetic drive.
Bought one from
Kansas Wind and Power, no connection with them.
5PV was on sale, YES
Oh, and the block heater part itself has already been installed. Factory aftermarket.
The in/out fittings were not in an optimal orientation for the chosen mounting location, which needs to be low in the system, and the male fitting meant another fitting to get down to size of the coolant lines. Lets just build another pump body and make it out of aluminum, and rotate the pump features where they will work for us.
Here’s a pic of all the pieces and the new pump body.
Yes the features in the new pump body are off center.
The out fitting in the flat on top needs to be moved over on the flat so the o-ring will seat fully against the flat surface. The internal features of the pump were shifted off center to be able to get this done.
The small barbed fittings for in/out, were borrowed from the PC cooling crowd. Very nice little fittings. They will be installed in the top flat of the new pump body. Those holes have not been machined yet, in the picture shown.
Where do we put this thing.
The plan is to weld a bracket to the oil filter spacer. The bracket will be cut from an aluminum gear box cover, discovered in the scrap tub. Need to get the pump body out from under the overhanging engine block in the area next to the oil filter.
Here’s a rendition of the finished weldment, taken from the solid model.
This pump will be powered by 12v power supply when the block heater is powered up.
Randall
