Engine Blanket Exposed Insight Gen1 - Insight Central: Honda Insight Forum
Old 01-22-2012, 02:33 AM   #1 (permalink)
highwater's Avatar
Default Engine Blanket Exposed Insight Gen1
OK here we go.
The best way I can come up with to do this is just load a pic in the gallery and the tell the story. I have a ton of pics and and to keep it all in order I think just me going by the pic number will keep the chronology straightened out. May have to back track some. The were a lot of mods done other than the blanket getting to the point of being able to wrap it such as I did, and that is undeniably material for another thread, I will mention it in detail sufficient to explain and try to stay on the blanket topic.
I cannot recommend anyone do this mod.
Those folks are absolutely correct when they say you will screw your engine up. Ask Willie about elevated coolant temps.
Were engine encapsulation, ever to be fully controlled with chips, that would be different.
I am the temp monitor and control. I look up at the ScanGuageII constantly.
I adjust the climate control as needed. I adjust the passengers window as needed. If I have to take the Interstate because of flooded roads, I can pull over and unzip the fly on the radiator block and cruise without having to monitor the temps. With the fly unzipped, the radiator has plenty of flow to keep the coolant at 197F without me touching anything.
My commute gives me the ability to cruise at 45/47, and I live in an sparsely populated area. My commute gives me a lot of things, I have always said that. FE is one of the things it gives me. I do not listen to music. I took the speakers out. I listen to the Insight. I don't have to worry with traffic.
My attention can be given to coolant temps.
The blanket goes on around Thanksgiving, and this last year it came of around the first of June.
I hope you enjoy.
Don't do this mod.
An edit for materials used and some results.
I used a product called Aramid Kevlar Pyreflect. It has excellent properties. The company that produces it is ADL Insulflex. Search you will find them. Got the high temp hook and loop, and high temp thread from them also. I do not believe they sell to the general public. I have channels that allowed me to obtain their product. It was pricey. You could buy you a nice grid charger and some IMA command and control stuff, for what I‘ve got in the engine blanket. I used the aluminum bubble insulation inside the sandwich. The outer skin is Sunbrella outdoor fabric, the stuff used for awnings and outdoor furniture cushions.
Results: The short response that I give to folks when asked about the performance of the blanket is this: I get 140F OBD indicated coolant in the dead of winter when using the block heater for 1 hour. This compares to 100F after 2 hours without the blanket.
I work long shifts, so pretty much all the heat is gone out of the block by the time I’m leaving for home. But, nice fast warm-ups, and the Insight and I are both very toasty and happy. That part is nice. I’m as warm as I want to be.
When the weather is not so cold and windy, I see around 35-40F warmer coolant than ambient, after sitting overnight.
I have some temp data captured, both OBD coolant and intake, and also the 8 channel thermo board that can be seen in a later post. It will take some time for me to revisit that.
EDIT 02/05/2012 added links to mediafire
I uploaded some of the files that were used for engine compartment temperature monitoring to Mediafire.
Engine compartment temps
OBD data
The file naming that I used goes something like this:
Insight 3 way Cat Temps_mmddyyX.
X is the trip number.
If the dates in the files don't match up with the file name, it is because when working the night shift, the trip in before midnight is saved as the first trip of the next calender day. Sunday night is Monday morning.
Randall
MIMA #005
A founding member: Knights of the MIMA Roundtable
highwater is offline   Reply With Quote
Old 01-22-2012, 02:39 AM   #2 (permalink)
highwater's Avatar
Default engine blanket and nose mitten
Just took these 2 a few minutes ago.
The underhood view.
And with the cover folded back.
MIMA #005
Old 01-22-2012, 02:43 AM   #3 (permalink)
highwater's Avatar
Default pre-install blanket
And the finished blanket pre-install.
MIMA #005
Old 01-22-2012, 02:44 AM   #4 (permalink)
I think that's damn good and looks quite oem well done.
What inside the blanket material, insulating vacum foil / bubbles?
Do you have patterns for the pieces?
Do you have any data on how it affects warm up time/temps/heat retention when parked etc etc
Could you log data to a graph for comparison with cover/on/off
Old 01-22-2012, 02:56 AM   #5 (permalink)
highwater's Avatar
Default rerouting lines underhood
Rerouted fuel line. It was also sleeved in abrasion resistant hose sock later.
Inbound goes behind intake manifold to keep it warm. Yes I know that won't work.
Also removed the crash bracket from around the VTEC. Had to flip the banjo fitting to a forward posistion. The original routing of the fuel lines went straight back. This was going to be in the way.
MIMA #005
Old 01-22-2012, 03:01 AM   #6 (permalink)
highwater's Avatar
Default more rerouting
The engine mounts are going to be points of penetration, along with the exhaust. Getting everything routed to go thru one of these points would keep things buttoned up. Here the ground cable is lengthened and routed near the engine mount. I eliminated one of the ground cables IIRC.
Hey Peter
Randall
MIMA #005
Old 01-22-2012, 03:20 AM   #7 (permalink)
highwater's Avatar
Default cutting out the material
I used old bed sheets and poster board, and cardboard to wrestle with making the patterns. I traced a full size pattern of all the pieces on kraft paper, before everything was sown up. Yes, he can operate a sewing machine. Sewed this blanket up with wifees old worn out Singer. Have the pattern rolled up in a tube around here somewhere. If I find a way to project that full size onto some media for to share with others, I have no problem sharing. Kinda like open source info. Someone know a way?
MIMA #005
Old 01-22-2012, 03:33 AM   #8 (permalink)
highwater's Avatar
Default Fan belts and pulleys might rub
One of the possible problems was that the blanket might be abraded from contact with the pulleys, in particular the AC pulley.
Thus the pulley paddle. Made from aluminum and conveyer belt.
From the bottom.
And from the top.
This also shows the rerouted fuel line and the missing vtec crash guard, and a peek of the Civic dip stick handle. The blade was cut off the Civic dip stick. Its just a hole plug. The extended reach of the Insight oil stick handle was in the way. The top of the paddle is mounted to a bracket that is mounted in the VTEC holes. The paddle is held with thumbscrews. Very short ones.
MIMA #005
Old 01-22-2012, 03:35 AM   #9 (permalink)
highwater's Avatar
Default material list and data
I will go back add edit the first post to include the materials used and share some data experience.
Randall
MIMA #005
Old 01-22-2012, 03:57 AM   #10 (permalink)
highwater's Avatar
Default Putting the pieces together on the engine.
These pics show some of the nit-picky things to work around getting the engine enclosed.
Beginning under the transmission on the vehicle left, this one is the left blanket panel above the left front axle. Note the little hole in the blanket above the axle. This is where the axle will reside, once the suspension is compressed with the weight of the front end.
The slit allows the axle to move up and down. The bottom edge will be zippered underneath the axle.
Moving around under the engine to the left, this is the exhaust penetration below the rear blanket panel.
MIMA #005
