Hi Guys,
I am watching this forum from overseas for a while now. And I enjoy my 1st-Gen Insight for more than 5 years.
I have made a few nice little modifications in that time like for instance a simple but effective car-pc with a 10" touch screen (who needs the air outlet in the middle anyway?), cruise control, sound module (
www.hiir.com) with car alarm and finally a park heater Webasto Thermo Top E.(Small and subcompact cars)
The only problem here is that the tiny tiny 12V battery in the Insight isnīt able to power the park heater long enough in the winter.
The heater needs 30 minutes to make my baby cozy and ready for a gentle warm engine start. But although I changed the 12V battery a few months ago the heater stops after 15min. I think it shuts off when the voltage drops under 9 or 10V.
And here is my question to all of you that understand more about the Insightīs electronics than me (so itīs nearly to all of you):
Is it possible to make the IMA battery (respectively the DC-DC module) charge the 12V battery even if the ignition is off? That would give me some ampere-hours to get warm and safe?
I already used the "fan relay" of the park heater to give power to the carīs climate control unit. Maybee I can do the same with the DC-DC module? Or do I need more components to charge the 12V battery?
The 12V battery has about 45Ah and I think the IMA battery with itīs ~900Wh could give me another 75Ah@12V. Am I right?
I hope someone can help me because Kiel/Germany is cold and snowy right now.
Many thanks in advance.
Nils
