Inelegant FAS ;-) - Insight Central: Honda Insight Forum
Old 02-03-2012, 10:39 PM   #1 (permalink)
Default Inelegant FAS ;-)
As practicioner of the inelegant FAS (key off), I've wondered for a while why we don't just intall switches, or relays, in all of the lines to the ignition switch. This is so obvious that it must have been asked before, so this will be a short thread
Old 02-03-2012, 10:47 PM   #2 (permalink)
Easier to just cut power to the fuel injectors.
Old 02-03-2012, 10:48 PM   #3 (permalink)
Maybe we are over engineering it? I ket off all the time when auto stop wont cut it or when I am driving my suzuki. I live on Hull St and our stop lights are fast at being green and 15 minutes at being red. I am not idling for 15 minutes.
Since my suz is a 95 it doesn't have fuel cut, so I key off and roll to a stop or pop the clutch to restart and keep going if the light accidentally turns green before I come to a stop.
Old 02-03-2012, 10:48 PM   #4 (permalink)
Yeah, lets save dumping raw fuel into the exhaust for purging NOX from lean burn.
Old 02-03-2012, 11:13 PM   #5 (permalink)
OK, that's a good answer. I was sure there must be one
Old 02-04-2012, 12:44 AM   #6 (permalink)
diamondlarry's Avatar
Did that. Takes less than 30 minutes to get it working.
Silver '00 MT
85.5 LMPG
Calpod switch
Warm air mod
Grill block
EPS fuse removed
grid charger
OBDII C&C gauge
Old 02-04-2012, 09:50 PM   #7 (permalink)
When you cut fuel and try to start it, how long will the ima system try to crank the car? Does it give a code when it fails starting? Have you tried cutting fuel while accelerating to make an EV mode?
Old 02-04-2012, 10:05 PM   #8 (permalink)
I use a momentary contact push-button switch for my fuel cut so I get a restart immediately. I have heard from Right Lane Cruiser that that as long as you hold the fuel cut switch in, you would have a limited EV-type function. I have not personally tried it yet.
Silver '00 MT
85.5 LMPG
Calpod switch
Warm air mod
Grill block
EPS fuse removed
grid charger
OBDII C&C gauge
Old 02-04-2012, 10:11 PM   #9 (permalink)
Premium Member
thedhgroup's Avatar
How long have you had your switch installed?
thedhgroup is offline   Reply With Quote
Old 02-04-2012, 10:34 PM   #10 (permalink)
I've had my switch installed for about a month now and love it. Since one of my main strategies for high FE is to avoid using the IMA and the FE penalty from when it needs to be replenished (hence the main reason for the clutch switch), I have not tried to use the EV capability that the fuel cut switch would allow for. I do use assist but just use it very sparingly and these mods are just tools to help achieve my goals.
Silver '00 MT
85.5 LMPG
Calpod switch
Warm air mod
Grill block
EPS fuse removed
grid charger
OBDII C&C gauge
