Accord Hybrid Motor in an Insight - Insight Central: Honda Insight Forum
Old 02-04-2012, 11:29 AM   #1 (permalink)
Default Accord Hybrid Motor in an Insight
Just wondering if anyone has thought about doing this? Seems possible and with some of the brains around here I'm sure it could be done. Not wanting to do this myself. Just thought I'd throw it out there for disscussion....
Redlinesd1 is offline   Reply With Quote
Old 02-04-2012, 12:11 PM   #2 (permalink)
RedJellyBean's Avatar
What I'd really like to see if a complete Prius II drivetrain and battery installed in an Insight. True EV functionality, much more powerful motor in a lighter-weight chassis should make the Insight wicked fast and still wickedly economical.
2002 Red Honda Insect 5MT
Old 02-04-2012, 12:22 PM   #3 (permalink)
samwichse's Avatar
I'd like to see an HCH engine/IMA in an I1, personally.
Seems like it would be a good fit, and you could still have all the IMA, lean burn and such, but a significant upgrade in torque and HP.
Sam
Old 02-04-2012, 12:49 PM   #4 (permalink)
02insight's Avatar
Sam
and 5spd also!
Old 02-04-2012, 03:11 PM   #5 (permalink)
Anything can be done... with enough money....
Old 02-04-2012, 05:38 PM   #6 (permalink)
02insight's Avatar
and time
Old 02-05-2012, 10:51 AM   #7 (permalink)
Vendor
It would be easier to put a 2003-2005 Civic 1.3 L4 into an Insight instead. The 2010+ Insights basically have that motor, but the gen1 Insights are much lighter.
