Your posted photo is not good/big enough to see detail.
Originally Posted by steveo
Anyone know how to program the Bms Master board or where to look?
You have to take it/them (The pics) out of the board and use a zif adapter connected to the programmer.
Is there any detailed photos other then the schematics of exactly how to wire everything together?
No. If you have studied and understand the schematics you should have an idea.
The master bus pins on the master board goto the master bus pins on the slave boards.
The slave bus pins on the master board goto the slave bus pins on the first slave board. Pin 1 goes to pin 1 etc. The slave boards are daisy chained together. The slave bus out on the first board goes to the slave bus in on the second board.
Connect up the Screen and a 12v supply to the Master board and the cells to the slave boards as has been described a few posts below. Then you should see something.
Also do i need to install the "vr1 - vr6" capasitors?
Not yet
is the bc337 transistor mouser part # 512-BC33716BU ok to use for Q1 ? .. i will use a 5- 10 amp supply?
I have no idea about that part number but any generic BC337 should do. Note the bc337 controls the charger 12v relay
not the charger directly, so the current you mentioned is only relevant to whatever 12v relay you choose to use.
Make sure everything you do is safe and
every cell is fused at the cell terminals. Read again all my posts in this thread and the original discussions. Mistakes now will fry the boards and I don't have any spares.
