soc reset - Page 3 - Insight Central: Honda Insight Forum
Old 11-11-2012, 10:52 PM   #21 (permalink)
It's the same reading as the OBDIIC&C Gauge - the SoC as perceived by the BCM. But yeah, pretty much.
Here's 3-Wheeler's implementation:
http://www.insightcentral.net/forums...4-post958.html
503-730-8786
info@bumblebeebatteries.com
Old 11-11-2012, 11:30 PM   #22 (permalink)
thedhgroup's Avatar
Thanks Eli. I could not find that one. That is what I meant by "tap into the BCM".
The power supply that runs my fan can probably power the BCM up too thus eliminating the need for waiting 2 min. or dealing with the drag charge in the morning. The first thing I do when driving out of the garage is climb a hill.
Proud owner of a Blue 2001 MT as of May 2011 and a 2006 Hybrid Accord as of 2009.
thedhgroup is online now   Reply With Quote
Old 11-12-2012, 12:04 AM   #23 (permalink)
Default SOC Reset after grid charge.
Powering the BCM is OK but there are number of caveats and gotcha's.
1) Why bother and just use an OBDIIC&C or Mike's SOC reset device to set the soc to 19 bars when you come out to the car in the morning after a grid charge. That takes about ten seconds.
2) If you decide to power the BCM overnight you must power it up before you turn on the charger or it will not count the current correctly.
3) Powering the BCM independently of the rest of the car electrics is best done by adding some diodes to it's 12v power feed wires and connecting an approx 1A 12v power supply on the BCM side of those diodes. Otherwise you end up powering up the whole car/ignition system. The car consumes quite a bit of 12v power when sat with just the ignition on (around 200w estimate) as we all know from how fast the 12V battery dies when the dc-dc converter is not working.
The IMA will also likely be energised and the DC-DC converter which means you waste a lot of the power in those systems as well.
I suggest someone uses a smart plug to count the KWH consumed by leaving the car turned on all night versus the BCM powered alone and versus just powering the grid charger and reseting the soc in the morning.
Old 11-12-2012, 12:56 AM   #24 (permalink)
Mike Dabrowski 2000's Avatar
Sure keeping the BCM powered up will record all the charging and indicate full in the morning, it will work no mater which charger you use.
My system disconnects the in car 12V from the fan circuit on both the + and - sides so the fact than my - 12 V fan power is also common with the HV ground is not an issue.
It is floating relative to the chassis and -12V ground.
If you try to run the BCM with the same 12V, then it is an issue, as the HV then gets connected to chassis ground.
A separate isolated 12V wall wart to power the BCM, and a couple of diodes and you can record the charge and will not require a reset, but as Peter says, it is not a big deal to do it through the OBDII port so why add the complexity?
I have also found that if the last SOC the BCM saw when you power off before the charge was < half scale, that the reset to full can happen on it's own when the car is turned back on.
Old 11-12-2012, 12:52 PM   #25 (permalink)
thedhgroup's Avatar
Money, or lack thereof... (I'm still saving up for a sparkfun 20x2 for a BCM gauge which I bought 14 months ago)
Old 11-14-2012, 10:07 AM   #26 (permalink)
First feedback from jracmw trying to reset his gen 1 civic with my SOC reset device is not encouraging.
Can someone that has Peters OBDIIC&C gauge that uses it on the civic tell us about their experience in resetting the civics to 19 bars.
Peter, have you received the SOC device I sent to you?
Old 11-14-2012, 10:11 AM   #27 (permalink)
Yes thanks got it the other day, but flat out at work for next couple of weeks. No civic to test it on either at the moment.
