I'm waiting on my OBDIIC&C to come in here on my end, just wondering if there is another way to reset soc after a grid charge, i understand if i pull fuse # 18 under the dash it should reset, i havn't had any luck getting it to work... is there a certain way i should be doing it for the car to recognize correctly upon start up?
thanks
-steveo
2002 honda Insight 5spd
Mima/BCM Fooler/BCM Interceptor/50s2p 40Ah A123/30% current mod/1000w charger
To Do: Install PP50 Bms, Charge plug, Warm Air Intake, led & hid lights
If I am looking at the correct fuse panel under the drivers side dash, just above the kick panel, how do you see any numbers? I don't see anything identifying each fuse.
Now I did find the IMA fuse in the engine bay and that was #18, didn't do anything tho.
How can I reset my SoC without purchasing more things? Would like to pull a fuse and not disconnect the battery to save my radio memory.
Trying to get it to the top after a charge isn't going to happen by pulling a fuse or the 12v. The car will be at zero and it will charge until it detects it is full. Of course this is a problem with your non-standard pack.
If you are running a lithium pack and a BCM interceptor your SOC should be fixed at 19 bars anyway if it is set up correctly. The whole point of the BCM interceptor was to fake 19 bars soc at all times unless the lithium pack was exhausted.
Your independent BMS should be telling you what the actual lithium battery soc is.
After my grid charge, I pulled fuse 18 (used OM to determine which one), replaced fuse,and drove the car for about 10 minutes. Soc re-established itself indicating 'full' battery. No need to rev engine to 3500 (as when pulling 12 v terminal). bty: OM indicated fuse 18 was lighting even though it was really soc indication.??
..Bob
'01 Red CVT US #218, 160K, Bought May '12 with 145k & 47.4 lmpg
Best commutes: 83.1 mpg / 50 miles, 72.2 / 100 miles. My commute: http://veloroutes.org/r/91468
Best tank 708 miles, 51.2 lmpg & climbing
Warm air mod & Grill block, AbCaRed00
Simple grid charger, Jeff652
4 1/2 acres of sovereign U.S. territory
Anytime, Anwhere,Go Navy or don't go
I just go out to the car with my lunchbox, turn the key ahead, go back in to get my laptop and morning drink of choice, kiss the wife and go back out to the car. By the time I get there it will be at 19 bars. Every time. I have my charger set to 169v. I think if it sees 168 or more for 2 minutes it does a positive recal. (on mine anyway)
(Sometimes) I just leave the key ahead and while plugged in the SOC creeps up on its own. This works good on 1 hour waits. (outlets are everywhere)
I have an 8amp charger up to 165v then a 700ma charger to take it to 169. So it only takes me an hour to charge it back up. (if it is not super hot out - then I just don't charge)
Once I accidentally left the key ahead overnight. When I got to the car the 20th bar was lit. It took FOREVER to drop to the 19th bar. I liked it.
Proud owner of a Blue 2001 MT as of May 2011 and a 2006 Hybrid Accord as of 2009.
