Cool alternative to ScanGauge + other OBD2 monitors - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 07-05-2012, 03:26 AM   #1 (permalink)
Send a message via AIM to AZhitman
Default Cool alternative to ScanGauge + other OBD2 monitors
I whipped up a product review article about the PLX Devices Kiwi, and this thing is awesome.
For a little more than $100, you get wireless connectivity to your ECU through your iPhone or Android smartphone, and can monitor damn near ALL engine parameters.
Check it out: PLX Devices Kiwi
3 matching 2000 Insight 5MT's (155K - 181K)
You're not doing the environment any favors by buying new cars - Keep 'em running!
AZhitman is offline   Reply With Quote Quick reply to this message
Old 07-05-2012, 10:50 AM   #2 (permalink)
2Slow4u's Avatar
I use this on my insight and it works pretty good. The MPG calcs are not very accurate but all the sensor readings are great. Plus you can view/clear codes, capture video with live data overlay (like a video vBox), and it links all the engine parameters to your GPS. Nifty little toy.
It stays in the insight, but I also use it on my other cars and even use the Torque applicaiton on my boat.
2001 Honda Insight CVT - 210k+ miles on the odometer
Best Tank 70 mpg over 700 miles
Best Segment 95 mpg over 103 miles
2Slow4u is offline   Reply With Quote Quick reply to this message
Old 07-06-2012, 02:38 AM   #3 (permalink)
If you go through and do the calibration, the FE calculations are actually pretty darn close.
We do the math (odo miles vs gallons used) and the dash computer reads about 2mpg low per tank. After calibration, the Kiwi came within 0.6mpg of accurate (tested over a 3-tank run).
My wife also has the Torque app loaded, and sets the Kiwi to display "instant fuel economy" on her Android (full-screen, digital bar gauge) and props it up on the speedometer bezel. She's learned how to plot the data, and is kicking my butt now by 2mpg over her last 2 tanks.
Old 07-06-2012, 11:45 PM   #4 (permalink)
Thermactor's Avatar
I pretty much tossed my Scangauge in the garbage once I got my OBDIIC&C gauge... the OBDIIC&C is pretty much the only game in town for the Insight IMO.
A contraction of the words "thermal reactor". former RedJellyBean
2000 Honda Insight
3-speed transmission (1st, 2nd, 4th)
Bad battery
Lots of engine malfunction codes
wet seatbelts, crappy stereo, lots of rattles
still runs, still driving
Thermactor is offline   Reply With Quote Quick reply to this message
Old 07-07-2012, 11:58 AM   #5 (permalink)
Premium Member
samwichse's Avatar
Agreed, even if the OBDIIC&C showed nothing about the engine and only the hybrid system, it would STILL be worth it.
Sam
Old 07-07-2012, 07:50 PM   #6 (permalink)
It really would be pretty easy to make the OBDIIC&C Gauge wireless. A transmitter to transmit the parallel LCD data and the LCD could be remote mounted. Perhaps with a small lithium battery and USB port to recharge it.
I'm not aware of any parallel transmitters off hand, but you could use a serial transmitter and a PIC to translate if you were handy with such things.
Home of the BeeMax performance IMA battery.
503-730-8786
Bumblebee Hybrid Fleet:
2000 MT Insight @ 250k; 2001 MT Insight @ 475k; 2001 MT Insight @ 160k; 2001 MT Insight @ 201k; 2003 MT HCH @ 160k; 2006 CVT HCH2 @ 205k; 2007 CVT FEH @ 210k; 2010 CVT Insight2 @ 191k; 2001 MT Insight @ 182k.
Eli is offline   Reply With Quote Quick reply to this message
Old 07-08-2012, 12:27 AM   #7 (permalink)
A serial lcd and simple transmitter/rxd pair would be the way to go if you want a remote lcd.
A small code change all that would be reqd to drive the serial lcd.
Pcb's/Built Units for ObdIIc&c, Imac&c, ImaBoost, Current Hacks available. Enqs to 150mpg[at]gmail.com
retepsnikrep is offline   Reply With Quote Quick reply to this message
Old 07-08-2012, 02:10 AM   #8 (permalink)
madmanmostafa
Guest
Posts: n/a
It would be cool to have just a tiny thin little screen and a thin little plug and have all the bulk hidden behind dash near the obd2 port. But I already dropped all the money for my gauge. Only way I'm replacing mine is if it kicks the bucket.
Old 07-15-2012, 05:23 PM   #9 (permalink)
This is what I've been using on my vehicles. Significantly cheaper then Kiwi. They also have mini versions out now that are nice and small.
ELM327 v1.5 OBDII OBD2 Bluetooth Auto Car Diagnostic Interface | eBay
I haven't used the full power of Torque app yet, but am slowly learning.
I don't know much about electronics but aren't these just bluetooth transmitters and the real power is in the Torque app software? Meaning couldn't it be transmitted to a wireless obdiic&c?
Truck
Truck is offline   Reply With Quote Quick reply to this message
Random Question
