In g-2 mods and tech issues (I still haven't figured out to copy a post from g-2 to g-1) there is some discussion about the fumoto oil drain valve (gilbertguy reply to capsmp with link to fumoto oil valve).
Part number appears to F-106N (N designates with nipple), with size listed as 14mm, 1.5.
The thread includes discussion about torquing the original drain plug and use of crush washers (14mm crush washer / 18mm for cvt)
Is there a different size fumoto valve for the cvt, or does 14mm work for both mt & cvt oil pans?
Does the brass valve pose a bi-metalic corrosion problem against the magnesium oil pan?
Will the fiber gasket discussed in that thread serve as a di-electric protector?
Sounds like a good device, are the G-1 owners using this?
..Bob
'01 Red CVT US #218, 160K, Bought May '12 with 145k & 47.4 lmpg
Best commutes: 83.1 mpg / 50 miles, 72.2 / 100 miles. My commute: http://veloroutes.org/r/91468
Best tank 708 miles, 50.9 lmpg & climbing
Warm air mod & Grill block, AbCaRed00
Simple grid charger, Jeff652
4 1/2 acres of sovereign U.S. territory
Anytime, Anwhere,Go Navy or don't go
#4 Yes, there are numerous G1'ers that have installed them.
Use: 320,000 mi. @ 57.8 LMPG
Dissimilar metal electrolysis requires a conducting electrolyte between the two metals. The oil between the two metals is an electrical insulator, so electrolysis shouldn't be a problem.
Aloha,
Art Isbell
2000 Insight A/C #559
I performed my first oil change with the Fumoto valve installed yesterday. I don't plan on removing it any time soon!! Made things much easier and less messy.
Yes, love my fumoto valve on my 2002 CVT! I cheat and leave a length of hose attached to the nipple and can reach down from the top of the engine and do the whole oil change without crawling around or removing the under-car aero panels! Sweet! I might have gotten lucky with the angle of the valve and being able reach the lever.
2002 Silver CVT, Rostra Cruise, ScanGauge, Fumoto Valve.
IMA Battery replaced 2010@60K miles.
Currently 105K miles, LMPG-59.9
A picky point - where the thread of the pan meets the thread of the valve there is an electrical connection. But I don't think that it matters in this situation, at least nobody had brought it up as a problem - yet.
Rush
Tucson AZ
Somebody suggested to get the extension, so I did. Good advice. Get the extension piece along with the valve.
2006 Insight
Bought it on 10/10/2010
