Where can I find instructions on disconnecting the IMA battery? - Insight Central: Honda Insight Forum
Old 11-02-2012, 08:31 PM   #1 (permalink)
Default Where can I find instructions on disconnecting the IMA battery?
I have been looking for the past hour and I don't seem to have any luck. I have the plate off and the IMA battery is exposed. I just don't know what to disconnect so I can go just on the gas engine.
Do you have any resources or recommendations?
Thank you so much! - Gabriel
GabrielMoss is offline   Reply With Quote
Old 11-02-2012, 08:47 PM   #2 (permalink)
ericbecky's Avatar
Attached is a picture courtesy of Eli of Bumblebee batteries
Disconnect three (3) wiring harnesses circled in red.
** One (1) is near the rear hatch and is visible in the picture.
** The other two (2) are near the passenger seat and are hidden from view in this picture.
If you kneel on the passenger seat looking towards the back of the car, you'll see these two better.
EV Powers: A Green-vehicle workshop in Madison, WI
Eric@EVPowers.com
608-729-4082
http://www.EVPowers.com
ericbecky is offline   Reply With Quote
Old 11-02-2012, 09:59 PM   #3 (permalink)
Default WOW, Thank you!
I did what you said and it works perfectly.
I really appreciate it!
Old 11-03-2012, 12:29 AM   #4 (permalink)
Glad it worked for you, remember to have the IMA battery switch off also. Please also add your location to your signiture block.
Tags
ima battery
