Need an MT - Insight Central: Honda Insight Forum
Old 11-25-2012, 01:10 PM   #1 (permalink)
JimIsbell's Avatar
Default Need an MT
I know that in the near future I will need a new tranny. The synchronisers are gone on 2nd and 1st gears. So far, its drivable if I dont push it. But the day will come that it has to be replaced. Its my only car for now so I need to get the replacement in hand before its needed so it will be a one day affair to swap it out.
Anyone out there know of an MT with realatively low mileage that might be available real cheap?
2000, 5 speed, 270,000 miles Silver
2000, 5 speed, 141,000 miles Red
Old 11-25-2012, 01:31 PM   #2 (permalink)
Lean Burn = Happiness
jeff652's Avatar
You have a PM
Old 11-25-2012, 02:08 PM   #3 (permalink)
Bugone's Avatar
Can a gearbox be fixed?
Ocean '00 MT
Continental Eco Contact 5s in 185/60/14.
Warm air mod
Grill block
Grid Charger with timer
OBDII C&C gauge
12v solar charger
IMA solar charger
6.5in touchscreen HU
5000k HIDs
Bugone is offline   Reply With Quote
Old 11-25-2012, 03:10 PM   #4 (permalink)
there is a junkyard in houston which has one with low miles. It wasnt cheap though, I think it was around 500-600. They also had the engine for around the same price.
Here is their number if you want to call 713 477 1000
Old 11-25-2012, 06:01 PM   #5 (permalink)
Need4Speed's Avatar
Bugone - what do you mean by fixed? Jeff has been able to rebuild them to eliminate the synchro problems and replace bearings.
2001 Red CVT
Email dave@groe.us
Old 11-25-2012, 08:20 PM   #6 (permalink)
You can drive with the worn clocking tabs pretty much indefinitely. The transmission in Insight #2 was driven for another 260,000 miles after the grinding first appeared.
503-730-8786
info@bumblebeebatteries.com
Old 11-25-2012, 11:29 PM   #7 (permalink)
JimIsbell's Avatar
Yeah, thats not the part I am worried about. Its the grinding every time I forget to slow below 20 to downshift to 2nd that I think will do it in.
Old 11-25-2012, 11:37 PM   #8 (permalink)
Maybe eventually the clocking tabs will wear away enough that the grind stops.
It really sounds much worse than it is; it will never result in the transmission failing. You could always learn to double clutch.
I drove an Insight recently and I didn't even realize it had the downshift grind, double clutching is just second nature to me now.
503-730-8786
Old 11-25-2012, 11:40 PM   #9 (permalink)
JimIsbell's Avatar
I tried double clutching and it didnt help. I guess I am in too much of a hurry to wait seconds.
Old 11-25-2012, 11:49 PM   #10 (permalink)
The quicker you double clutch, the more smooth the transition will be. With practice, it only takes marginally longer than a regular downshift. It should all happen very quickly, certainly less than 1 second.
Just takes practice, not unlike learning to drive a manual transmission in the first place. I could hop in your car and downshift into 2nd gear at 55MPH with no grind.
Anyway, just saying. I know there's value in having things that work properly. It's just funny because I double clutch even in the cars without grind now.
503-730-8786
Tags
scynchronizers, transmission
