I've been thinking what the effect would be of adding an electric turbo (supercharger) to an Insight, to boost low rpm performance.
Now I know that the junk on ebay doesn't put anywhere near enough air to have any effect on a 'normal' cars performance. However on an Insight, you would be looking to improving power at low rpms where airflow is generally a lot lower.
I've been reading about the new Audi electric turbo. I'm sure that would put out a fair amount of air. Probably way too much for an insight. However it does show that the concept is valid.
Plus of course, the insight also does have an abundance of electrical capacity compared to a normal car.
Thoughts?
Ocean '00 MT
Continental Eco Contact 5s in 185/60/14.
Warm air mod
Grill block
Grid Charger with timer
OBDII C&C gauge
12v solar charger
IMA solar charger
6.5in touchscreen HU
5000k HIDs
The folks on ecomodder say no. I want to get a cfm meter and measure the intake draft and the output of a leaf blower. If they look like a possible gain, Id like to try the 2 with an inverter and see if anything is gained with seat of the pants dyno.
The key there is "In conjunction with a conventional turbo".
The idea of how to do it is valid, but it is also very complicated.
I wonder what kind of motor they use to spin the turbo to 50K?
(If only I had the bucks to play)
Use: 320,000 mi. @ 57.8 LMPG
This is something I have thought about in the past as well. A 5psi supercharger (or even turbo) would be great but do it 'properly' will cost £££s. It is a shame we don't have the same level of fabricators and garage shops that they seem to have in America.
2005 Insight, UK Spec Silver 5 speed with Grid Charger, IMA C&C, Alpine stereo & subwoofer & speakers & iPod link, Matiz rear springs, Shark Fin aerial, 165/70/14 Continental tyres, Garmin EcoRoute HD, Skinz sound deadened rear shelf, 'InsightCentral' number plates, 19" rear wiper, K&N air filter
Previous owner of 1999 Japanese Silver 5sp, 2001 UK Citrus 5sp & 2000 Japanese Red CVT Honda Insight - An extraordinary car for ordinary people
In the link is a diagram of the Audi setup. Wonder if many people will be buying the Audi turbo as a part, to install n other cars.
Ocean '00 MT
Warm air mod
Grill block
OBDII C&C gauge
12v solar charger
IMA solar charger
5000k HIDs
Hasn't this been done by the VW group before, with their supercharged / turbocharged TSI engines?
Sadly the trouble is to buy the part separately will still cost £££s.
I don't think he used the IMA battery, I believe he had an extra 12V battery installed.
His motor was basically a 12V starter if I remember right.
Guess I had better search/research again.
I don't know of any Insighter that has his mod.
It wouldn't be a supercharger but rather just a supercharger. You guys are grossly underestimating the HP required to provide positive boost. Even for our little engine, to get 1 PSI will take at least 2 HP, @ 12 V would be 125 amps even at 144 V is 10 amps (not counting for losses in converting to high frequency commutation for a "brush-less" DC motor), turning at well over 100,000 RPM. With the existing Compression ratio, getting detonation will be easy , as a result, the timing will be retarded by the knock sensor and there will be no net gain (except to look cool).
