Removing friction from steering system - Page 2 - Insight Central: Honda Insight Forum
Old 12-20-2012, 10:30 PM   #11 (permalink)
samwichse's Avatar
My Civic hybrid also has the honda EPS system and "stiction" is exactly the right term for it... it's by far the worst thing about driving the car. A normal I1 doesn't feel like that, it should be very easy and return to center quickly (mine did, my dad's does).
All info I've seen on the HCH1 said "replace the steering rack" ($$$$), except one guy that said the torque sensor binds and recommended spraying oil into it. I'm going to try that first, otherwise... ouch, my wallet!
Sam
-OBDIIC&C
-IMAC&C
-Lower grill block
Old 12-21-2012, 02:17 AM   #12 (permalink)
Originally Posted by Willie Williford View Post
Why remove the motor. Fuse out, no load.
Why carry unnecessary weight?
It would be good to know the following:
1) How much the EPS motor weighs?
2) If with the unit removed whether there is a noticeable reduction in steering effort compared to with only the EPS fuse removed?
pascal28 is offline   Reply With Quote
Old 12-21-2012, 02:29 AM   #13 (permalink)
Mario's Avatar
Weight is probably negligible, I wouldn't estimate it at more than 8-10 pounds. But, it probably has a gearbox, which will cause quite a bit of drag even if the motor is connected to nothing. I'd say it'll make a difference.
Mario is offline   Reply With Quote
Old 12-30-2012, 01:10 PM   #14 (permalink)
Wocketman's Avatar
Send a message via Skype™ to Wocketman
Well I finally took the PS motor off. Once you get the battery/box out, the motor and associated plugs are not too hard to get at.
However, in my case the motor was frozen/corroded into place. So tight that after the two main mounting bolts were removed, it was still completely stuck. Had to use a sharp chisel driven between the motor/base and the mounting flange on the steering rack!
But got it off, sprayed a bit of lube inside the opening (there is a small splined shaft in the bottom), and covered up the opening with a nice old small thick sock...
So, how does it drive? MUCH BETTER! There is almost no stiction at all now. Even when steering while backing out of parking lots/etc. it almost seems like there is still power steering. Happiness.
For all the great things about these Gen 1's, putting PS on them was the lamest idea. Right up there with putting the seat tilt levers on the inside of the seats away from the doors...
Wocketman is offline   Reply With Quote
Old 12-30-2012, 01:23 PM   #15 (permalink)
diamondlarry's Avatar
In the older cars I used to drive, the non-power steering versions had a different steering gear ratio than their powered counterparts. Could this be the case on our Insights?
Silver '00 MT
90.2 LMPG
Calpod switch
Warm air mod
Grill block
EPS fuse removed
grid charger
OBDII C&C gauge
Old 12-30-2012, 01:47 PM   #16 (permalink)
Thank you for the experiment and the report. I may have to find time to do that myself. With us all going over the fiscal cliff, and the country practically shutting down, I'll have more time on my hands for "cheap" stuff to do
Old 12-30-2012, 01:50 PM   #17 (permalink)
Wocketman's Avatar
Cliff? What cliff? I think that's all imaginary...
And if it's real, build up enough speed to reach the other side!
S
Old 12-30-2012, 02:03 PM   #18 (permalink)
S
Spoken like a true Wocketman
Old 12-31-2012, 11:05 AM   #19 (permalink)
Very interesting finding!
A few questions:
1) Do you have a picture of the bit(s) removed?
2) How much weight did this mod save?
3) Is the EPS light on?
4) Has it affected anything else?
Old 12-31-2012, 11:18 AM   #20 (permalink)
Wocketman's Avatar
No pics yet, when I did it was running late to meet friends for skiing...
Not much weight really, it's a very small motor.
Yes, EPS light still on. I know there's a fix for that but haven't done it yet.
Nothing else affected so far, AFAIK!
