03 HCH Hybrid Battery Rebuild - Insight Central: Honda Insight Forum
Old 01-28-2013, 12:31 PM   #1 (permalink)
Default 03 HCH Hybrid Battery Rebuild
Hello Everyone,
I am new to this forum. I come here because I heard this was the place with experts so I hope I can find my answers here. I am sure these questions have been asked. But I have looked and there are no specifics on these issues.
So, I have started the Hybrid Battery Rebuild. I removed the battery yesterday. I broke the battery down to its individual sticks. And I have started charging the Cells. Once I charge then I will be Cycling them.
I have a few questions:
1. What was the charge rate you were using? I started using 3.3A. But I heard one of the batteries relieve pressure. So I backed down to 2.3A. And that seemed to work. I am using a Triton EQ charger for this.
2. I know there will be bad cells. Does anyone know where I could get individual sticks? If not, does anyone know where I could get a cheap pack. I will go ahead and test all those individually also.
Any advice, information or warnings would be helpful. Thank you again.
Base430 is offline   Reply With Quote
Old 01-28-2013, 12:38 PM   #2 (permalink)
TopFuelTim's Avatar
Eli is one of the battery gurus on this forum. Although his business (Bumblebee Batteries) is new sticks / batteries, I believe he will sell old ones if asked. Not sure why you heard venting at 3.3 amps. What was your voltage and capacity set for?
FWIW, I use a Superbrain 989 for stick conditioning, and a Genesis 1 for pack conditioning.
My 0.02 worth,
Tim Glover
Old 01-28-2013, 12:45 PM   #3 (permalink)
Starting on page 5. There is no voltage or capacity inputs.
http://manuals.hobbico.com/gpm/gpmm3155-manual.pdf
Old 01-28-2013, 01:31 PM   #4 (permalink)
I believe that the "specifications" page gives you better information.
Use: 321,000 mi. @ 57.8 LMPG
07 FIT "S"
(3K made, The prototype one?)
Old 01-30-2013, 03:23 PM   #5 (permalink)
Thanks Willie for the response. I dont really see where it states the charging voltage and the capacity. I know the charger detects peak voltage and adjusts its amp charge rate.
I did have a pack that took over 5500 mah. All the others so far were around 2600 to 2900 mAh. After I complete the Charge/Discharge Process I will post the spreadsheet for comments.
Is there anyone else with advice on the Charge/Discharge rate they used?
Thank you everyone for their answers.
